GM70 SE 300B E80CC monoblocs
thanks Rajkom
i made a 6C4C PP driven by LL1660PP, E80CC and LL1540 input stage
this combination for 8W a 0,1% THD was excellent
PP 6B4G interstage DHT
Just saying if looking for alternative to AN, J&K Audio Design makes a tailor made OT Double-C for 880USD pair.
for output transformer i do not like coreC high impedance high voltage
but EI transformers. if standard OPT give - 2db 18/20 Khz
a perfect linear transformer price X3
so we are very happy with standard canadian OPT 1629SEA
if i find a flycase plenty of dollars i will buy better OPT
thanks anyway
I looked your website and you build impressive audiophile amplifiers.
I liked the PPP kt88 and GM70 PP, very special.
I read your modification of the music angel 845, you did a very great work especially replacing the OT with Hammond! 3.5% thd to 0.5 is incredible!
P.s. I too have a stock of 5691 RCA NOS NIB , they are exceptional tubes! same with the 6sn7 too, very good section balance and a transparent sound the new tube completely lack off.
I have experimented with, listened to, and measured various IT designs/topologies. Once I managed to find a design that allows bifilar winding design with appropriate DC interwinding voltages, I will never go back. I was never able to even remotely approach the bifilar performance with split bobbin or layered/sectionalized windings.
That being said, I also subscribe to the philosophy that IT topology is best implemented between driver and output stage, where impedances are optimized. Between input and driver stage, not so much; you are better off with cap coupled. Blocking distortion should be an output stage challenge; so fix it optimally with an IT. Only poor designs will suffer with blocking distortion between input and driver stage; therefore cap coupled is a very reasonable (and low distortion) solution.
Optimal device for the optimal stage, IMO.
Claudiomas,
I may have given you the wrong impression, I am sorry.
I have used interstage transformers in single ended amplifiers, and they sounded great.
Some were c core, some EI.
One interstage was EI and bifilar, and I used it with 4-65 Tetrode.
I used a push pull interstage with a current source and a cathode coupled phase splitter.
I also used an SE to PP interstage transformer as the phase invertor in a push pull amp, that had good performance too.
Like you, I only used EI output transformers.
Keep listening.
Keep building.
They are a beautiful build but feel the need to comment that more recent technology using class A transistors such as the JLH or HIRAGA amplifiers will sound better, have a much better transient response, higher s/n ratio, and cost much less. Having started off with a SET nearly 60 years ago, my comment is not without some personal experience. Those thinking about valves in any configuration should read Self.
  • 800a.pdf
