Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Tubes / Valves All about our sweet vacuum tubes :) Threads about Musical Instrument Amps of all kinds should be in the Instruments & Amps forum |
I am hoping you guys could help me out...PLEASE..
I'm having issues with my preamp and to make it worst its modded... one channel is out...now my local tech needs an schematics for it... there are C7 and C4 schematics online, and they are probably different...maybe C7.. any help?
Semper Fidelis! |
#2 |
This is not good ugh
Semper Fidelis! |
#3 |
While a schematic would help, having one channel that works and one that doesn't provides a ton of information on how to proceed on the repair.
The first step for the tech would be to take voltage readings on each tube pin on the working channel, then repeat the process for the non working channel. There will likely be a difference in voltages between working and non-working (and if there isn't, that's also super informative). The specific differences will tell you how to proceed with the repair. If both channels are out, that's more annoying, but most often a power supply issue. Luckily you don't have that going on. |
#4 |
Thanks! Yeah he did say he will just trace it.. being mdded he said doesn’t help at all
Semper Fidelis! |
Thread | Thread Starter | Forum | Replies | Last Post |
precision fidelity C-9 preamp input tubes | armed | Tubes / Valves | 6 | 6th March 2018 03:55 AM |
Precision Fidelity C8 pre | ShaneF | Tubes / Valves | 20 | 17th December 2016 02:11 AM |
Help Precision Fidelity M-7 amp | asmith | Tubes / Valves | 4 | 2nd September 2016 12:01 PM |
Precision Fidelity M8 | reon | Solid State | 6 | 21st April 2015 05:48 PM |
precision fidelity | chevy_lvu | Solid State | 0 | 26th March 2008 07:42 AM |
New To Site? | Need Help? |
