Need help identifying a tube/valve
Old 16th April 2018, 07:21 PM   #1
popilin is offline popilin  Argentina
popilin's Avatar
Default Need help identifying a tube/valve
Hi all
As far as I know, Haltron is a rebrander, so what is the original?
Thanks in advance.
Just to avoid copyright complaints, the image was taken from here
https://articulo.mercadolibre.com.ar...altron-nib-_JM
I do not suffer from insanity, I enjoy every minute of it. - Edgar Allan Poe
He has the most who is most content with the least. - Diogenes of Sinope
Old 16th April 2018, 07:48 PM   #2
DF96 is offline DF96  England
That looks Russian.
Old 16th April 2018, 08:09 PM   #3
popilin's Avatar
Oh no!
They cost about U$S100.- here...
Thanks a lot DF! A reference as ever.
Old 16th April 2018, 08:13 PM   #4
kylej1050 is offline kylej1050  United States
Yeah that construction looks a lot like some 6N23P tubes I have at home.
Old 16th April 2018, 08:17 PM   #5
Jim McShane is offline Jim McShane  United States
The "flying saucer" shaped getter indicates it is Russian. You can see it pretty well in the right hand image.
Old 16th April 2018, 08:18 PM   #6
popilin's Avatar
OK, thank you very much to both.
Old 16th April 2018, 09:52 PM   #7
popilin's Avatar
I found a 6N23P which looks almost the same, except for the gold pins.
6N23P = E88CC = 6DJ8 = 6922 tube. Double triodes ― Hi-End vacuum tubes, sockets, capacitors, nixie. Retail and wholesale to worldwide.
Old 17th April 2018, 12:54 PM   #8
Kay Pirinha is offline Kay Pirinha  Germany
Kay Pirinha's Avatar
A 6N23P tube ain't no bad tube at all, especially in it's -EV version. But it also ain't worth one hundred bucks, just due to gold plating it's pins.
Best regards!
"Bless you, Sister. May all your sons be bishops." (Brendan Behan)
Old 17th April 2018, 12:54 PM   #9
kstagger is offline kstagger  United States
kstagger's Avatar
And the pointy pins also point to a Russian tube.
Old 17th April 2018, 01:42 PM   #10
popilin's Avatar
Best regards!
Hallo
A less than U$S10.- valve for about U$S100.- is too much, you guys saved me to lose a lot of my scarce money.
My cousin will travel to Germany on next May, do you know a reliable valve seller in Germany? Thanks in advance, and sorry off topic.
I do not know many Russian tubes/valves, but I did see this detail yesterday searching for 6N23P pictures. Thank you very much.
Need help identifying a tube/valveHide this!Advertise here!
Help Identifying A Valve Amplifier Bassy Tubes / Valves 17 13th June 2016 05:49 PM
Convert a non-valve amp to a Valve (tube) Amp seanthomas46 Instruments and Amps 17 20th April 2015 04:11 AM
Help Identifying Valve Amplifier Aleks1 Tubes / Valves 4 3rd September 2014 05:15 PM
Help identifying tube amp iko Tubes / Valves 3 3rd October 2008 12:52 AM
Help with identifying tube showdown Tubes / Valves 1 24th November 2005 09:05 PM
