Intriguing measures on tube amp
Old 16th April 2018, 08:03 PM   #41
dady is offline dady  Balearic Islands
dady's Avatar
Send a message via MSN to dady Intriguing measures on tube amp
Originally Posted by petertub View Post
It is two different things to build :
- an amp that reproduces music as it is recorded
and
- and amp that is sweet to the ears
It all boils down to what the goal of the amp.
HEHE but now, how you know which of all the reproductions are as it recorded"?
Esteban Bikić
Old 16th April 2018, 08:04 PM   #42
dady's Avatar
Originally Posted by DF96 View Post
Item 1 is an opinion. Items 2 to 7 are facts.
Or not...
Esteban Bikić
Old 16th April 2018, 08:27 PM   #43
dady's Avatar
Right now, I can not became overwhelmed with the capacity of people, technician, profane, experts to find conclusions in nowhere, far from any question and showing like masters their findings about nothing to add, simply criticizing the readings of the common men. But now I don't want to add any to them saying that, in the matter you asking Mr Jama, I can say, humble more than ever... We are biologic machines, in this kind of devices, the result of the mathematical operations always are approximate, music is a subjective expression, volatile and always is impossible to find a numerical response.
Esteban Bikić
Old 16th April 2018, 08:53 PM   #44
audiowize is offline audiowize  United States
Send a message via AIM to audiowize
Originally Posted by popilin View Post
As for GNF, you cannot correct in the present (output) an event of the past (input),
So opamps don't work...
Old 16th April 2018, 09:08 PM   #45
popilin is offline popilin  Argentina
popilin's Avatar
Op Amps sucks, even to make a decent PSU...
I do not suffer from insanity, I enjoy every minute of it. - Edgar Allan Poe
He has the most who is most content with the least. - Diogenes of Sinope
Old 17th April 2018, 09:59 AM   #46
6A3sUMMER is offline 6A3sUMMER  United States
dady,
You Said:
Is possible to guess that the distortion of the amp cancel the response of the speaker ?
Answer:
Speakers have 2nd harmonic distortion. Single Ended amps have 2nd harmonic distortion.
You can either increase or partially cancel the 2nd harmonic distortion, by connecting the speaker up one way or the other (the + and - leads to match the amp + and - out;
and then with the + and - leads opposite to the amp out).
One experiment used a double pole double throw switch from the SE amp out to the speaker.
Just one channel and one speaker was used, and a 100Hz tone from a low distortion oscillator.
One person switched the switch, and the other person listened. Then the two people
swapped who had the switch, and who listened.
The Timbre of the sound did change depending on the switch position.
This is similar to the cancellation of the 2nd harmonic distortion of a push pull amp.
No attempt was made to say which switch position was preferred, the experiment was just to prove that there was an easily discernible difference.
Old 17th April 2018, 12:22 PM   #47
dady's Avatar
I did this last afternoon with my J2 and my full range speakers. Some change inside...
Esteban Bikić
Old 17th April 2018, 12:23 PM   #48
dady's Avatar
Thanks SixAthree summer....!
Esteban Bikić
Old 17th April 2018, 01:36 PM   #49
gabdx is offline gabdx  Canada
I find the 3rd 4th and 5th very low, and there are no other higher distortion.
High 2nd distortion is ok relative to a push-pull amp which cancels (in tests especially!) the 2nd harmonics. 2nd are mostly harmless, the wave form is simply asymmetric in the horizontal plane.
A good pair of speakers have -30 to -35 db of distortion below music level at 2 meters at 95db. This makes the whole amplifier distortion a quasi-non issue. We only use thd to try to improve amplifiers and make sure we are not making a design worse.
The only negative aspect of this amplifier is that if paired with a low sensitivity speaker the sound will soft clip which will blur musical impacts and details of low signals making the sound soft and homogenous/euphoric.
As 6A3sUMMER pointed out, this is a very basic performing 300B amplifier, still with great audio and THD in my opinion.
I have a set of amplifiers from 2 watt to 100 watts, the low wattage sounds lovely, but as the power increases the resolution of the speaker increases too. Be happy with your amplifier and keep it.
amplificateurslegrand.ca
Old 17th April 2018, 01:42 PM   #50
Originally Posted by jama View Post
Why?. I do not understand why this harmonic pattern sound so good when I have seen a lot better harmonics pattern in a others amps, and the final sound is worse, for my taste.
For example, I own an original J2 from Nelson. I have measure the same. Look image. This is the original J2 (best amplifier of 2017, Stereophile). For me, sound is not as good as tube amp. All music is more transparent, more details and instruments separation with elekit. J2 is an incredible amp (is my second amp), but I feel 'more' hearing with 300b.. And this is the problem, why?. Measures are better with J2, harmonics are a lot lower in value...
This response is produced with less linear components as you can see the ramp of high order harmonics. This is also a feedback design it would appear which has not a good control of the high harmonics vs your tube amplifier.
This type of amplifier has a loud sound with less realism. feedback introduce 3rd harmonics which are not measurable and mask low level signals. When the amplifier is near clipping I suspect the ramp of high harmonics will raise dramatically with a very harsh sound and more musical blurring.
Intriguing measures on tube ampHide this!Advertise here!
Kenwood Basic M2 - Intriguing Circuitry SVI2004A Solid State 33 23rd May 2012 09:39 AM
Intriguing Circuit, LOOK farmerjack61 Multi-Way 11 15th November 2010 12:59 PM
Pointless, yet intriguing. NinjaKitten Everything Else 13 25th November 2008 09:28 PM
