Found schematic 50W EL34 AB. Needs help...
Old 15th April 2018, 06:48 PM   #11
artosalo is offline artosalo  Finland
artosalo's Avatar
I have tested different EL34 PP amplifiers with fixed bias and with 6F12P triode pentode front end. With 4k output transformer and 460 V +Ub the available output power is from 55 W (UL) to 72 W (pentode).
Attached the schematic and some test results.
Old 15th April 2018, 10:40 PM   #12
Zekk is offline Zekk  Singapore
Hi Arto...Can I use your GU-50 power supply for this schematic?
Thanks!
Zekk
Old 16th April 2018, 05:59 AM   #13
CaterpilarSK is offline CaterpilarSK  Slovakia
Originally Posted by kodabmx View Post
You should be able to get full power with about 1V input.
Great. Thanks. I sent you a direct message. Please check.
Old 16th April 2018, 06:26 AM   #14
artosalo's Avatar
Thanks!
Zekk
Basically you can, but that PS has regulated screen grid voltage too, that is not necessary required if +Ub is some 450 V and of course not with UL.
I have used this. The 68 V zener in this schematic can be replaced with a small electrolytic capacitor.
Then input voltage variations has the same effect on all voltages and less effect to idle current of output tubes.
Found schematic 50W EL34 AB. Needs help...Hide this!Advertise here!
Someone help: SE shematic with GK71? bezobraznia Tubes / Valves 30 24th April 2011 12:17 AM
Looking for PP 7027a shematic 807tubenut Tubes / Valves 1 21st August 2010 07:52 PM
Classe DAC-1. shematic vadimgal Digital Source 3 21st September 2006 06:53 PM
NEC A10 shematic vd-two Solid State 0 5th April 2005 10:08 AM
shematic of vincent cd s1.1 alchemy Digital Source 5 29th October 2004 01:31 PM
