hey guys. it's late and i'm too lazy to go into detail (maybe tomarrow) but following the instructions here: http://www.tubecad.com/articles_2003...ier/index.html
when I was working on my minimalist amplifier design gave me a grid bias voltage of 17mV for a sv572-160 driver tube. Does that sound right? |
#2 |
diyAudio Moderator Emeritus
Clearly incorrect. Check the tube's datasheet.
#3 |
hi
here is a copy of the tech data sheet for the -160 http://www.svetlana.com\graphics\pro...\SV572-160.pdf funny thing about the svetlana site is that all the information under the main banner is still there. I could see that the bias point may in fact be 17volts, you need power to drive this thing, as it operates in A2, this means a low impedance source, probably a cathode follower, or an interstage tranny in the anode cct of the driver stage, with bias introduced through the other end of the secondary. best of luck. bill ramsay: |
| Changing grid leak bias preamp to cathode bias | bereanbill | Tubes / Valves | 8 | 28th March 2009 05:26 PM |
| Battery grid bias to fixed bias in Toccato? | w00t | Tubes / Valves | 3 | 2nd December 2007 12:34 AM |
| CCS Grid Bias | rdf | Tubes / Valves | 12 | 11th December 2006 05:26 AM |
| grid LED bias? | fred76 | Tubes / Valves | 13 | 4th August 2006 12:00 AM |
| 0v grid bias with UL connection? | AudioGeek | Tubes / Valves | 0 | 8th July 2006 06:57 PM |
