New project 300B
New project 300B
Old 13th April 2018, 11:37 AM   #1
xcicc is offline xcicc  Italy
xcicc's Avatar
Default New project 300B
hello to everyone, rummaging through old hard drives I found this amp scheme. I do not remember who designed it or anything. I'd like to build it, I'm going to ask you that you're definitely more experienced than me, does it seem like a very good project?
Old 13th April 2018, 12:37 PM   #2
waltube is offline waltube  Italy
waltube's Avatar
I don't like that project. The 300B must be driven from linear stuff similar to it. In this way the first stage with 6922 in srpp and the second stage with 6H30 also in srpp is a good choiche. in case you can use a single E88C (not E88CC) in SRPP, it is a very interesting solution because is involed only one amplification stage to drive the 300B why not E88C
Walter
Old 13th April 2018, 01:24 PM   #3
artosalo is offline artosalo  Finland
artosalo's Avatar
To me it looks that ECL82 is used proper way. It is especially know as a very linear tube. And also refreshing to see a project of 300B with intention to better performance, i.e. with NFB.
Old 13th April 2018, 01:46 PM   #4
xcicc's Avatar
Hello yes, I agree with your analysis thanks
Old 13th April 2018, 01:47 PM   #5
xcicc's Avatar
.... I add that in my opinion 90% for a good tube amp are the output transformers. Correct me if I'm wrong
Old 13th April 2018, 01:50 PM   #6
mbrennwa is offline mbrennwa  Switzerland
mbrennwa's Avatar
+1
[ audioroot.net | hifibau.ch ]
Old 13th April 2018, 04:45 PM   #7
Adolf Corkscrew is offline Adolf Corkscrew  Finland
Am I the only one here a wee bit concerned about how those screen and control grids are connected in the pentode half of the ECL82? I fail to see how connecting the control grid directly to the anode would not end up in a spectacular failure of the tube.
Old 13th April 2018, 04:53 PM   #8
xcicc's Avatar
Sure? I have serious doubts about it. How should it be connected?
Old 13th April 2018, 05:09 PM   #9
They're the wrong way around. The control grid (g1) should be connected where the screen is now, and the screen grid tied to the anode. That makes the pentode section behave as a triode.
Old 13th April 2018, 05:35 PM   #10
waltube's Avatar
Maybe is an error on drawining the circuit. The intention is to use the pentode as triode. In addition this circuit is using a 5u4 with 310+310 vac (and a mix of fixed an cathode bias) the Vdc is low to reach a right power. In every case I can't undersand the use of a pentode as triode when there are other stuff bettere than this solution
Last, the OT must be a the best this to justify the money to buy a pair of 300B
Walter
New project 300BHide this!Advertise here!
300B amp project Hun7er Tubes / Valves 26 20th September 2015 10:57 AM
which 300B project? help please Mach_Y Tubes / Valves 165 23rd January 2014 04:56 AM
My 300B project... widowmaker Tubes / Valves 10 9th January 2007 10:35 PM
