what is the simplest possible triode amp? - diyAudio
Old 12th April 2004, 07:38 PM   #1
Default what is the simplest possible triode amp?
Is this the simplest you can get with a tube amp? From what I understand the basics of an amp go like this:
1) Signal goes through a coupling capacitor to eleminate DC
2) Signal goes to tube grid and modulates DC current from plate to collector
3) modulated DC goes through a output transformer
4) profit?
Old 12th April 2004, 08:11 PM   #2
frugal-phile(tm)
planet10's Avatar
Default Re: what is the simplest possible triode amp?
With no DC from the source you could lose the input coupling cap, and the cathode bypass may not be necessary... you do need a grid leak resistor thou (and a power supply)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 12th April 2004, 08:49 PM   #3
thanks dave, the only reason I put the cathode bypass in there is I always see it in other designs. What's it for anyway?
Old 12th April 2004, 08:51 PM   #4
On Hiatus
SY's Avatar
The bypass increases gain and lowers source Z, at the expense of increasing distortion.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 12th April 2004, 09:02 PM   #5
wow thanks guys. im learning a lot! Is a grid leak resistor simply a resistor infront of the grid? So I could basically simplify it down to this?
Also, what are the advantages of using more complicated designs versus ultra-minimal ones like this one? And do I need a resistor between the collector and outpot transformer?
Old 12th April 2004, 09:05 PM   #6
On Hiatus
SY's Avatar
The grid leak is a high-value (50K->10meg) resistor that goes from the grid to ground (or other reference point). Its purpose is to hold the grid at ground on a DC basis. The size is chosen to be as large as possible, consistent with the expected grid leakage current of the tube.
Old 12th April 2004, 09:06 PM   #7
That would be a grid stopper. A grid leak goes from the grid to ground. No, you don't need a resistor between the plate and the transformer, but you could replace the transformer with a resistor.
Here's a good article that should answer many of your questions:
http://www.tubecad.com/articles_2003...ier/index.html
Old 12th April 2004, 09:09 PM   #8
SY:
What would be the effect of putting a battery under the cathode (assuming there's a CCS up on top for setting the current, and the battery's voltage is equal to the required bias voltage)? Would that be equivalent to a cathode resistor bypassed with a (near) infinitely large capacitor? In other words, maximum possible gain, lowest possible output impedance, and highest possible distortion?
Old 12th April 2004, 09:13 PM   #9
On Hiatus
SY's Avatar
Yeah, it would be pretty close. The differences would be around the fringes: the battery will have a higher source Z than the cap-bypass at high frequencies and a lower source Z at very low frequencies. But basically, the same.
Old 12th April 2004, 09:17 PM   #10
thank you guys so much for the education. saurav your link is bookmarked!
Another 3f4 spice triode model: 5718 submini triode wa2ise Tubes / Valves 0 5th September 2008 04:31 AM
PP-Triode , PP-UL , PP-Pentode-strapped-as-Triode percy Tubes / Valves 23 22nd January 2007 12:36 AM
Simplest DAC audioPT Digital Source 1 19th April 2003 04:06 AM
Looking for the simplest DAC ever... martioz Digital Source 4 7th March 2003 03:09 PM
Simplest possible Mr. Triatic Solid State 7 17th October 2002 09:11 AM
Copyright 1999-2017 diyAudio
