Repairing Hi-End Preamplifier
Joined 2009
Yups just missed. I used the attached schemati, only change -3.3V in place of -3V at grid.
Administrator
Joined 2004
Hi Merlin,
If the capacitor wasn't there, the plate voltage of the tube would be very low and performance wouldn't be good. Also, the core of the transformer would have a large DC component which would shove the operating point up into a very non-linear portion of the B-H curve.
analog_sa gave you the answer to this question.
-Chris
Hi merlin,
I would believe that if I could see a resistor in the ground return to generate that bias voltage. It's probably there and is simply missing as an error in the schematic.
A corrected schematic would be nice so we don't have to guess at things.
-Chris
Apart from a few resistors used for the LED supplies there are none in the audio path or inductor's (excluding transformers). The small transformers in the preamp are used for balanced input and output and do not feature if just rca input and outputs are used.
The amp is currently all back together but I have a NOS Tung-sol JTL5687 to fit some time soon so I'll remeasure any voltages people are interested in.
