Edcor GXSE5-600-15K for 300B HPA
Joined 2009
OPT screen
Screen to signal ground or not to screen?
Joined 2009
Wattage 5W
Max. Current 100mA
Primary (input) Impedance 15K Ohms
Screen/Grid Tap 40%
Secondary (output) Impedance Depends on model.
Frequency Response 40~18K Hz., <1dBu
THD+Noise <0.1% @ 1K Hz.
Bobbin Material Nylon 6/6 GF-30
Flamability Rating Class B 130°C
Core Material M-6 29 ga. grain oriented lamination steel
Secondary Insulation (transformer) Clear air dry polyester varnish
Termination 0.187" (3/16") quick disconnects
Mounting Zinc plated steel channel/frame
Weight 1.2 lbs.
Compliance RoHS & REACH
Yes I read it but my ignorance don't let me see or understand:eek:.
In technical English the word "screen" may mean:
1. an electrostatic screen - for example, as included in some power transformers - this should be grounded
2. an abbreviation of 'screen grid' - for example, as included as a tap in UL output transformers - this should be connected to the screen grid (for UL) or left isolated (for pentode or triode operation).
Ex-Moderator
Joined 2011
:cop: @merlin - please do not start multiple threads on the same topic. Your threads have been merged. :cop:
Sorry about my comments above, but you can do what the rest of us do when we read in a foreign language, use Google Translate:
Screen/Grid Tap 40% = Pantalla / Grilla Tap 40%
OTOH, if you don't know what the screen tap is for, then it's a different matter...
