Takatsuki 300B Problems Audionote kit1
Old 27th March 2018, 04:17 PM   #1
seanxk is offline seanxk
Unhappy Takatsuki 300B Problems Audionote kit1
Hi all, thought I might add this thread although I'm sure my 300B is shot ( looking for another single in sale section ).
3 years in and not a great deal of use on my Audionote kit1, one valve started flashing blue wildly, I contacted Amtrans in Japan where purchased, asking for help and advice, they certainly played the language game and just came back with an unhelpful '' They only have a 1 year warranty '' ( I know ). I tried again and asked if they have used singles available only to get the generalised generic answer '' no we don't ''.
I feel I have just been unlucky and have just got a dud, one does hope for more than 3 years use, the other one tests out at approx 90% good, but if anyone has an idea if I can rescue the dud I'm all open.. they are not cheap ( on my valve tester, the heater is not showing heat at 5V, but does work as voltage is increased, then shorts/blue flashes as full test comes in )
Many thanks, Sean.
Old 27th March 2018, 04:57 PM   #2
jdarg is offline jdarg  United States
There's no easy fix if that's what you are asking. Would you want to risk the amp with a "rescued" tube anyway?
There no gaurantee a $1000 tube will last any longer than a $100 one. It's just the nature of the tube game. I'd say if you can't stand to replace them every year or two, regardless of use, maybe aim a bit lower on the price scale. Frankly I'm just happy when a tube failure is caught quickly and doesn't damage the amp. I'd rather replace tubes and maybe some passives vs. transformers generally speaking.
Old 27th March 2018, 07:14 PM   #3
Palustris is offline Palustris  United States
Palustris's Avatar
There no guarantee a $1000 tube will last any longer than a $100 one
Actually, Emission Labs has a five year guarantee on their 300B tubes. I have been using the EML 320B XLS for a couple of year already and the build quality is superb and the sound beautiful. A pair of EML 300B with the five year guarantee is US$570 at today's exchange rate.
Last edited by Palustris; 27th March 2018 at 07:16 PM. Reason: made price specific
Old 27th March 2018, 08:07 PM   #4
Thanks for the replies, on one hand how can you guarantee a valve in any respect, but very reassuring that EML offer 5 years, good customer relations I think.
Funny enough the only valves I have ever had go wrong were new versions, Mullards, GEC and the like just seem to fade away.
Old 27th March 2018, 09:49 PM   #5
FullRangeMan is offline FullRangeMan  Brazil
FullRangeMan's Avatar
I would suggest sell this 300B amp ASAP and buy a popular Pentode amp where you can use cheap tubes as 6L6/EL34/6550/KT88/90/120/150 as Triode or better yet a GU50 amp $5 USD each.
GU50
>Never go to a psychiatrist, adopt a cat or dog from the streets. On the streets pets live only two years average.
Old 27th March 2018, 10:13 PM   #6
kevinkr's Avatar
The EML 300B is a great choice as is the JJ 300B for a little less money.
I'm seriously assuming you will just replace the tubes and not sell the AN Kit1.
BTW I got more than 5000 hours of trouble free service over 10 years out of a pair of JJ 300B and they are now sitting on a shelf still good as spares for my soon to be completed 300B mid/tweeter amps.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 27th March 2018, 10:32 PM   #7
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
i am currently building a 2A3 set that can make use of the JJ2A3-40, but can also use the traditional 2A3's at lower voltages, by just changing taps on the power traffo...
i once had a Takatsuki pair of 300b's on my bench when the owner brought an Antique sound lab set, when i learned about the price, i quickly called the owner to pick those up, while i was repairing the amp, and asked for the cheaper tubes instead..
i am converting that amp to cathode resistor bias, so that he can swap tubes easily without need for rebiasing...
the owner of the ASL also had an audio note kit 1 amp, and it is cathode resistor biased..
i have heard stories about 300b's red plating, and i did not believe until i saw it on the ASL amp...
no sad stories so far with the 2A3's...
so yes, just get another pair of tubes and plug it in and enjoy...
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 27th March 2018, 10:42 PM   #8
kmtang is offline kmtang  Canada
kmtang's Avatar
I am very happy with the Gold Lion 300B from Russia. Good price and great performance.
Old 27th March 2018, 10:47 PM   #9
RajkoM is offline RajkoM  Bosnia and Herzegovina
RajkoM's Avatar
I have 300B SET for 17-18 years already (I listen about 3-4 hours a day, average)
Now it's just second pair of great NOS =C= 300B in my amp all this time.
I've never had any problems.
I always turn-ON all my tube gear very slow, with a 2.5KVA "Siemens" Medical variable power transformer.
Old 28th March 2018, 12:38 AM   #10
Do you could inform the model or a link?
Takatsuki 300B Problems Audionote kit1Hide this!Advertise here!
WTB. 300B Takatsuki x1 seanxk Swap Meet 2 27th March 2018 08:16 PM
FS: Takatsuki 300B tube pair wyan Swap Meet 1 28th March 2016 07:50 AM
My audionote Kit one have problem on 300B cathode terminal ramnmic Tubes / Valves 4 13th January 2005 06:56 AM
Transfomer Too hot on my AudioNote 300B kit one audionote Tubes / Valves 7 6th November 2003 11:20 AM
Audio Note DAC KIT1.2 component list and power transformer spec PTSOUNDLAB Digital Source 2 13th May 2003 06:55 AM
