Would this work - diyAudio
Old 11th April 2004, 11:07 PM   #1
Default Would this work
Y hallo there! This is my fist attempt at designing any sort of amp, and I would like to know if it would even work!
Old 12th April 2004, 12:02 AM   #2
I havent given any of the components values b/c I honestly don't know what to give them! It all sort of depends on the tubes you know? I was thinking of perhaps some 6C19s. a data sheet of them would be uselful.
Old 12th April 2004, 01:00 AM   #3
diyAudio Senior Member
fdegrove's Avatar
Errrrr....Whazzzdat??
DATASHEET...SORT OF.
Frank
Old 12th April 2004, 01:53 AM   #4
Would you recomend that tube? I'm new to this! Is my basic amplifier scematic solid?
Old 12th April 2004, 01:57 AM   #5
fdegrove's Avatar
All I can do is some wild guesses...What is it for and why these bootstraps at the output?
I can't seem to figure out what it is you want to do with it really...
I certainly plan to use it in the near future, the feedback I heard from others seems quite positive so why not...
Frank
Old 12th April 2004, 01:58 AM   #6
ok, it said voltage control so i was confused. the schematic is for a minimalist tube amplifier. All I want to do with it is to be able to say I built a simple amp that sounds great. The crisscross inverter thingy on the output is a stupid idea I had of a way to avoid putting a capacitor directly in the output line (it seems to me like a cap there would depreciate SQ) Or would grounding each side with an inductor work just as well?
Would this work ? LesPaulStandard Instruments and Amps 3 4th May 2006 03:14 AM
Will This Work? sousmielie Class D 6 27th December 2005 06:53 PM
It Should Not Work ! f4bok Solid State 3 6th September 2004 06:33 PM
Would this work? JoeBob Solid State 5 18th July 2003 04:40 PM
Copyright 1999-2017 diyAudio
