PSU for 6N13P tube
PSU for 6N13P tube
Old 23rd March 2018, 10:30 PM   #41
indaco is offline indaco
Ok, I'll try for some measurement.
I've used the IRF822, the IRF740 and the 2SK3567 (this one is an old mosfet I think but the one working "better" than others).
Old 24th March 2018, 12:08 AM   #42
GoatGuy is offline GoatGuy  United States
GoatGuy's Avatar
Well, for “starters”, the 2SK3567 has a bipolar zener protecting the gate from excessive gate-source voltage. The VMAX of that is 30 V. Its hard to kill it in practice.
Looking up the IRF740 you have http://www.vishay.com/docs/91054/91054.pdf … and its micro-diagram doesn't have the protective Zener. Blow the gate oxide, and there goes that parade. Its a biscuit.
The IRF822 only has a 20 volt gate-source absmax rating. And no zener. I've gotten so used to deploying fully protected ("faultless") MOSFETs that I've dropped including protection circuitry for them in diagrams. Both of these may be blown devices, now. The 2SK3567 will likely still be good.
Again, measure a few voltages.
GoatGuy
John Curl's Golden Rule…: 100 kHz bandwidth, 3 μs risetime, 100 W mean output, 100 V/μs slew rate, 2 Ω dynamic load, 20 amp min current source/sink
Old 24th March 2018, 01:36 AM   #43
Okay, I tried again but it seems working with IRF740 (I used a 12 volt zener G-S). Output voltage increasing until 181 V (with 200k/200K voltage divider). Input voltage is 370 V coming from two RC after diode bridge. The strange thing is that load resistor here must be high, that is > 50k instead 33k otherwise my multimeter becomes "crazy" and doesn't show any number on the display (as it's off range). What could be it?
Old 24th March 2018, 08:08 PM   #44
Ok, I think I resolved through the LR8N3 regulator with mosfet + current limiter. It's a nice circuit, stable voltage at 175 V - 100 mA and the only device to cool is the mosfet with a suitable heatsink.
Old 25th March 2018, 12:47 AM   #45
GoatGuy's Avatar
Well, that works too. Good call.
Old 26th March 2018, 01:02 PM   #46
In wich section can I post some photo of my DIY amp related to this PSU? It was just set to work, but must be finished.
Old 26th March 2018, 02:14 PM   #47
Lingwendil is offline Lingwendil  United States
Now with high-fructose ASSAULT-gluten!
Lingwendil's Avatar
PSU for 6N13P tube
You can post it on this thread, just upload the pics to the post.
Check out My 6SN7 Push-pull Flea Amplifier project! PCB COMING SOON!
Old 26th March 2018, 06:53 PM   #48
Here some picture
Old 26th March 2018, 07:27 PM   #49
Sorry for the wire mess in the first picture At the end I used a BU808 as voltage regulator (as capacitance multiplier) because I shorted the LR8N3 by an accident on the breadboard.
PSU for 6N13P tubeHide this!Advertise here!
Tube amp reboot Re: Chinese 6P6P (6V6) Push-Pull Tube Amplifier Kit ts761100 Tubes / Valves 14 31st March 2016 09:40 PM
5687 tube-based preamp with Tung-Sol Black plates, Sylvana and Phillips ECG tube pair networld Swap Meet 3 10th August 2014 01:23 AM
FS: Yaqin CD-1 Tube Buffer w/Mullard 6DJ8 Tube. Adds tube warmth to any system. matevana Swap Meet 2 15th June 2013 12:35 PM
need diy tube preamp (line-stage) recommendation and general tube advice Musiclover4 Tubes / Valves 16 18th May 2013 03:19 PM
found tube i like, only small bits of red letter,what tube brands used red lettering? ryuji Tubes / Valves 2 15th April 2011 11:24 PM
