SE SV-811-10 power supply
Old 13th April 2018, 08:37 PM   #41
Lewis1 is offline Lewis1  United States
Default model vs. breadboard
I modeled my latest design for the B+ power supply in PSUD. Took a screenshot of how it shows the PS will perform at no load (actually a 1mA load). Runs about 870V. Then I breadboarded it and got 865V. Pretty close!
When loaded, I think I will get a bit over 600V B+. The schematic calls for 500, but the SV811 seems like it would be happy with 600. Am I wrong about that?
Old 13th April 2018, 10:41 PM   #42
audiowize is offline audiowize  United States
Send a message via AIM to audiowize
Originally Posted by Lewis1 View Post
I was surprised to see this statement in the help section on the transformer/rectifier: "For full wave rectifiers, use the voltage for one side only. For example, if the transformer off load voltage is 350-0-350V (700V end to end), the correct value to enter is 350."
Does that seem right? Isn't that for a half wave rectifier?
Think about it this way:
For a full wave rectifier with the CT grounded, fold it in half and it kinda looks like two half wave circuits in parallel.
Old 15th April 2018, 11:06 PM   #43
Default Progress!
Making some progress on the SV811-10 monoblocks. Pics show one chassis with the layout diagram drawn directly on it. Then I skipped over a lot of tedious cutting, drilling, sanding, priming and painting to show the bookended pair after shooting with a couple coats of two-part urethane.
Old 15th April 2018, 11:10 PM   #44
Default Power supply coming along
Then the last two are bottom views showing most of the power supply components squeezed in. I was able to get everything into the outside third of the chassis, with a little distance from the driver tube.
Old 15th April 2018, 11:12 PM   #45
Default Thanks, Audiowize and a question about point-to-point wiring
Audiowize, that is a helpful way to visualize it. Thanks!
Because of the tube layout, there will be a few inches between the 6EM7 and the SV811. Where should the coupling cap go? Close to the driver? To the SV811? In the middle? Or does it matter?
Thanks,
Lewis
Old 16th April 2018, 02:07 PM   #46
It doesn't really matter.
Old 17th April 2018, 03:05 AM   #47
Default Tonight's winner in the category of "ridiculously over-engineered"
I want a point to bring all the power supply grounds to, and I want it off the chassis. I didn't have anything suitable, so I made a pair of the little guy in the pic. It's a piece of acrylic stock, center drilled on the lathe, then tapped 10-32 on one end for a button-head machine screw to attach to the chassis, and tapped 10-24 on the other end for a brass stud to collect all the ground leads. Ain't DIY great? Imagine a production shop taking an hour to make a pair of stand-offs!
Old 17th April 2018, 11:38 AM   #48
jdg123 is offline jdg123  United States
jdg123's Avatar
Thatís the best fun of this pursuit, taking care of the unique needs of ones own design. Nice work!
Old 20th April 2018, 09:40 PM   #49
Default 6.3V DC too high?
I put together the DC power supply for the SV811 pretty much exactly like it is shown here: SV811/SV572 SE1. The transformer puts out about 7.4V unloaded. Rectified, I get about 8.6V DC unloaded, which makes sense (7.4 X 1.4 = 10.4, minus a little less than 2V for the bridge and diode).
Isn't that going to be way too high?
Old 20th April 2018, 10:09 PM   #50
w5jag is offline w5jag  United States
The tubes draw 4 amps filament current each, so the voltage drop will be substantial.
I used two Vishay MBR1645 rectifier diodes, about 10K uF, and got right at 6.3 VDC at the tubes.
I think you'll be okay.
Win W5JAG
SE SV-811-10 power supplyHide this!Advertise here!
If a DAC asks for a 7v - 9V power supply, should I used a 9v 2000 mA power supply, or ag8908 Digital Line Level 2 26th March 2014 06:24 PM
Making Symmetric Power Supply from Single with 4x ATX power Supply? lupetalo Power Supplies 11 20th November 2012 11:51 AM
Power supply positive-negative-ground from a single power supply mome Power Supplies 8 9th September 2011 05:17 PM
Hagerman Bugle power-supply or for +/-15dc 100ma generic supply. tweakk Swap Meet 3 23rd February 2011 06:46 PM
