Super-Triode SE amplifier
Old 7th March 2018, 12:13 PM   #1
Tyimo is offline Tyimo  Hungary
Default Super-Triode SE amplifier
Hi!
Would this amplifier work as it is on the Tube Cad schematic?
Single-Ended Amplifiers & Super-Triodes
What type should be the NPN transistor?
What kind of OPT need this circuit?
Greets:
Tyimo
File Type: png Super-Triode Single-Ended Amplifier with ECC99.png (36.7 KB, 628 views)
"Replacing any coupling capacitors with a well designed and correctly matched driver or interstage transformer yields an almost shocking improvement in sound..." Peter Qvortrup
Old 7th March 2018, 01:35 PM   #2
Lingwendil is offline Lingwendil  United States
Lingwendil's Avatar
I experienced bias drift on the handful of these circuits i messed with, I wouldn't really recommend it unless you are prepared to go really deep into the rabbit hole to optimize it, Broskie goes further into discussion on it in later posts that may be helpful.
Check out My 6SN7 Push-pull Flea Amplifier project!
Old 7th March 2018, 08:06 PM   #3
stocktrader200 is offline stocktrader200  Canada
I used 6922 with 400v MJE13005 in a push pull config for 30w on 150 B+
Old 8th March 2018, 10:28 AM   #4
I experienced bias drift on the handful of these circuits i messed with, I wouldn't really recommend it unless you are prepared to go really deep into the rabbit hole to optimize it....
What a pity, because it seemed logical and simple.
Old 8th March 2018, 11:12 AM   #5
KlausB is offline KlausB  Germany
KlausB's Avatar
Hi Tyimo,
I did some calculations on SuperTriodes that can be found here.
new power amp
and I posted a real life amp here
SuperTriode with BJT and MosFet - a good idea?
Greetings
KlausB
Old 8th March 2018, 02:06 PM   #6
Sodacose is offline Sodacose  United States
Sodacose's Avatar
Any updates on your project? Still using it?
I read through that thread/schematic a while ago when on a super triode bender.
WTF Amps || /r/diytubes/
Old 8th March 2018, 05:34 PM   #7
Thanks KlausB!
Fantastic site!
Old 15th March 2018, 08:08 PM   #8
KlausB's Avatar
I am sorry, something went wrong with the link to my website.
Here is the correct link
new power amp intro
Cheers
KlausB
Old 16th March 2018, 07:46 AM   #9
Thank you!!!
Super-Triode SE amplifierHide this!Advertise here!
Has anyone here built something with this super triode? Molloy Tubes / Valves 11 18th February 2018 07:22 PM
Super cheap triode amplifier aldovan Tubes / Valves 100 25th May 2014 08:29 AM
Super Triode Connection Amplifier Build with 6BM8 and 6AK5 DerFly Tubes / Valves 35 3rd November 2009 07:45 AM
