ECL85/6GV8 PP Supertriode
Old 8th March 2018, 09:33 PM   #11
stocktrader200 is offline stocktrader200  Canada
3 * 3 tube amp posted here 3 x 3 Tube amp 30 watts
Old 9th March 2018, 08:32 AM   #12
tikiroo is offline tikiroo  New Zealand
Thanks, I do actually remember seeing that at the time. A lot of interesting stuff flies under the radar on this forum
What power do you get out of it? With mine the anode voltage can be pulled down to about 40V minimum giving power of (155-40)^2*2/400 = 66W. Yours maybe 15-20W with 200V B+ and 3500 ohm primary, probably more of it would be in class A.
ECL85/6GV8 PP SupertriodeHide this!Advertise here!
SuperTriode with BJT and MosFet - a good idea? KlausB Tubes / Valves 27 22nd October 2017 10:59 AM
6GV8 at lowish voltage mashaffer Tubes / Valves 6 19th August 2011 01:46 AM
6V6 SE VS ECL85 J_Hart_14 Tubes / Valves 22 14th December 2010 01:15 PM
Supertriode with PNP transistors Hylle Tubes / Valves 8 8th June 2010 07:04 AM
G. Kaufman's 6GV8/ECL85 regulated psu fred76 Tubes / Valves 36 17th January 2006 08:21 AM
