First timer on a very low budget. I just want to build something, is this kit ok?
Old 2nd March 2018, 10:34 PM   #11
Pygmy is offline Pygmy  Netherlands
Originally Posted by reaper996 View Post
Nice. Does this come with an instruction note printed in bold on how I do not kill myself during assembly?
Old 2nd March 2018, 11:44 PM   #12
rayma is online now rayma  United States
Probably just a schematic.
Old 8th March 2018, 12:53 PM   #13
kylej1050 is offline kylej1050  United States
If you connect ground to your chassis I can't think of a way you'd kill yourself with a tube amp build. Obliterate some components? Sure.
If you ever find yourself probing around the chassis while it is running remember to keep a hand behind your back to avoid B+ to ground through you. For live probes I tend to use clips so I don't have to hold anything.
If you are reaaaaally worried about it there are low-voltage solid state buffered tube amp kits you can buy for under $20. They use the 6J1 or 6J5 tubes.
Old 8th March 2018, 01:04 PM   #14
e_fortier is offline e_fortier  Canada
e_fortier's Avatar
For complete kit look into the company “Oddwatt”
Eric
Old 12th March 2018, 06:57 PM   #15
cgnman59 is offline cgnman59  United States
cgnman59's Avatar
I second Oddwatt. I built their Alpha which is a 1 watt amp using a 6GV8 tube for each channel. It sounds surprisingly good. Everything is included. About all you need to supply is a good soldering iron, solder and then glue for the poplar wood base. After going through their checklist to ensure all was correctly soldered and set up, I ran audio through with no problems. I've just been listening to music through it for over a year now. I run a turntable and have my Klipsch KG3.5 speakers hooked up to it. It makes a great first project with a high probability for success. Documentation is excellent and if you have a question Bruce at Oddwatt is quick to respond to emails.
Old 24th March 2018, 04:44 PM   #16
spaceistheplace is offline spaceistheplace
spaceistheplace's Avatar
Default First timer on a very low budget. I just want to build something, is this kit ok?
Transcendent Sound makes some nice kits with very good documentation with safety procedures and so on. Bruce from transcendent sound is also the author of some good introductory books on tube amps and designs.
Bottlehead is another good option, as well as Tubelab and Oddwatt which were already mentioned.
Some sell kits or boards assuming you have a preexisting background, at your own risk but some out there are quite sympathetic to the novice as well. After all, we all began as novices at some point.
Between the companies I mentioned you should be able to easily find something that suits your needs.
Be sure to tell them your speaker sensitivity and ancillary equipment so they can recommend you the most suitable option.
This is a good option for ~4W. Requires minimal fiddling- set it and forget it. OTLís also cut one of the pricier parts of the builds out- OTs. Some swear by their sound as well.
Mini Beast
However for a novice on a budget why not try a DIY Pass solid state design? With these tube designs the output transformers as well as output tube replacements can be quite expensive. On a budget can mean different things for different people, but this can be $400-500 in transformers and tubes alone, not including the boards and other parts and chassis.
If you are set on tubes id encourage you to choose a design which incorporates tubes that donít have a huge following of guitar players or audionuts driving up NOS quality tube prices.... pick something off the radar.
The real aim of music is to co-ordinate the minds of the people into an intelligent reach for a better world and an intelligent approach to the living future.
Old 26th March 2018, 05:27 AM   #17
H713 is offline H713  United States
On the flip side, 6L6s and EL34s are super common, and I'd be surprised if they became expensive and rare in 10 years. When I was choosing my design one of my criteria was to use a popular tube that will likely always be available. Just another way of looking at this.
Old 26th March 2018, 02:11 PM   #18
Bangla H is offline Bangla H  Germany
Bangla H's Avatar
Hi Pygmy.
Could this be possible safe enough to build.
PCL86 Verstaerker Beschreibung
There are any other projects from Hans, take a look.
Aktually is running the little PCL86 here, with steps modified....after years of building,
finally.
Now i enjoy how it sounds, only slightly from powertransformer.
Here a source for needed Transformer and others..
Frag Jan zuerst- Ask Jan first: Roehren und mehr
send from my NOTEBOOK PC.
Old 26th March 2018, 02:19 PM   #19
Hi Bangla, as it's in german it's not clear to me whether this is sold as a complete kit or whether I should try to figure out myself what's needed and how to put it together.
Old 26th March 2018, 02:46 PM   #20
dovla is offline dovla
Default Kits from Italy
You have these nicely priced kits from Italy (shipping to the rest of EU)
PCL86 kit is only EUR 140 with all the parts included and it'd be an excellent way to learn
Kit per S.E. stereo di PCL86 - Amplificatori valvolari e kit
Kit componenti per S.E. stereo con EL34 o KT88 - Amplificatori valvolari e kit
First timer on a very low budget. I just want to build something, is this kit ok?Hide this!Advertise here!
First timer bookshelf build inchy97 Parts 9 20th May 2016 08:52 PM
First Timer ESL Build DriedChalk Planars & Exotics 11 29th January 2016 02:03 AM
First timer. SE or SSE build Stevemc79 Tubelab 2 10th September 2014 09:59 PM
2 way crossover build (diy first timer) Johnbob9 Analog Line Level 2 24th July 2011 02:09 AM
First timer build - Advice nightanole Chipamp 0 8th January 2010 06:37 PM
