Single Ended 2A3/6A3/6B4G DC coupled & Transformer choices
Old 7th March 2018, 07:41 PM   #111
RajkoM is online now RajkoM  Bosnia and Herzegovina
RajkoM's Avatar
Why too much ???
I like your ideas. When I find a power transformer and order 2A3, I will do something with this amp.
Old 7th March 2018, 07:45 PM   #112
Perfectusaudio is offline Perfectusaudio  Australia
Nice to see a 5K load on the 300B - euro21 - once the inductive part of the load is included the suggested resistive load does not always work .
Old 7th March 2018, 07:50 PM   #113
inductive plate load ellipse
File Type: png Screen Shot 2018-03-08 at 6.48.48 am.png (401.8 KB, 193 views)
Old 7th March 2018, 10:05 PM   #114
RajkoM's Avatar
Originally Posted by soulmerchant View Post
I think that if one used a "statistical regulator",...
Ian,
What should be the maximum voltage ripple on the input of the statistic regulator?
Is CRC enough before?
I do not have any experience with that regulator.
Old 8th March 2018, 11:35 PM   #115
soulmerchant is offline soulmerchant  Switzerland
soulmerchant's Avatar
From Morgan Jones' Valve Amplifiers (4th Edition):
"The statistical regulator is certain to have >90dB ripple attenuation, so this corresponds to it tolerating 53Vpk-pk ripple post rectification."
Of course it pays to read his book in full. The circuit is not at all complex and he explains it in great detail.
Ian
It's harder to make real audio than special effects audio.
Alejandro Gonzalez Inarritu
Old 9th March 2018, 12:54 AM   #116
Bigun is offline Bigun  Canada
Bigun's Avatar
I thought this thread had ruled out use of sand, the 'statistical regulator' uses a sand based current source. I have thought about using a tube-based CCS but it does make the thing more difficult and if you want anything remotely close in terms of performance I would imagine it getting complicated.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 9th March 2018, 08:04 AM   #117
Hanze Khronye is offline Hanze Khronye  Australia
Originally Posted by pieter t View Post
Specifications are sometimes cleverly "stretched".
When you take a close look at the frequency curve of your example, it is obvious that it includes the first resonance.
The real curve starts falling at about 30 kHz.
Monolith Magnetics ? - simply has to be who else specifies 7Hz - 151kHz so specifically?
THEY state very clearly that stated BW is without resonance, so how to counter that?
Knowing resonance is when Xl = Xc... looking at the (f) vs amplitude plots, how can you arrive at such a conclusion?
I suppose you know this guys math/ physics is at a very high level, Phd level, and he lectures in that/those subject/s.
There is a commercial amplifier which openly admits to using these OPT, claims measured BW out to >140kHz in circuit, retails for 25k USD
The Truth | Whammerdyne Heavy Industries
Have to say that I am leaning toward thinking that you are short on this one.
Hanze.
Old 9th March 2018, 08:55 AM   #118
Hi Hanze
Sure you may see something around 100kHz on the Tektronix I have but it will be over 30 dB down
Such a load of crap
Old 9th March 2018, 09:02 AM   #119
Default OPT
Old Tektronix TM515
Old 9th March 2018, 11:18 AM   #120
RajkoM's Avatar
Tnx Ian.
I see M.Jones using CLC before his SR.
Perfectusaudio, please apologize for my OT`s.
No more !
Single Ended 2A3/6A3/6B4G DC coupled & Transformer choicesHide this!Advertise here!
Single Ended Output Transformer mensur Tubes / Valves 1 24th August 2016 02:50 AM
Single ended transformer as pushpull? jim Tubes / Valves 22 10th July 2014 05:54 PM
Bipolar ps from single ended transformer dmtparker Power Supplies 4 13th September 2013 12:16 PM
Calculating DC coupled Single Ended Valve Amplifiers - Part #1 ThorstenL Tubes / Valves 31 18th December 2012 03:16 AM
Edcor CXSE25-8-2.5K single ended UL transformer joseangel Tubes / Valves 3 4th February 2012 02:38 PM
