12AX7 gain test
12AX7 gain test
Old 18th February 2018, 04:23 AM   #21
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
I have never really got on well with the 12ax7.
I find I have trouble getting rid of noise.
It needs great care especially if concatenated.
Both halves of the valve need decoupling separately.
Most of my designs use the 12AU7. It has less gain but is easy to manage.
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk
Old 18th February 2018, 04:28 PM   #22
Lingwendil is offline Lingwendil  United States
Now with high-fructose ASSAULT-gluten!
Lingwendil's Avatar
12AX7 gain test
I don't like the 12AX7 or 12AU7 for much more than guitar amplifier applications. I find that the 12AX7 takes too much work to perform well for low distortion... and the 6N2P or 6SL7 will work much better in their place, albeit with lower gain. The 12AU7 usually ends up a cathode follower to be useful when I have to use them. The 6CG7, 6SN7, or 6N1P are much better choices for applications that need similar gain and lower plate resistance.
Check out My 6SN7 Push-pull Flea Amplifier project! PCB COMING SOON!
Old 18th February 2018, 04:50 PM   #23
DF96 is offline DF96  England
Originally Posted by artosalo
Cathode bias is negative feedback for DC, which means that it essentially "hide" some difference between the tubes under test.
But grid leak bias varies quite a bit from valve to valve, so is a poor way to compare them unless you intend to use this bias method in the actual circuit.
12AX7/ECC83 is fine when you want high gain and low distortion and are prepared to do a proper design. If not, use an easier valve.
12AX7 gain testHide this!Advertise here!
12AX7 Switched Listening Test PB2 Instruments and Amps 10 25th April 2015 10:09 PM
12AX7 high gain guitar amp razorrick1293 Instruments and Amps 27 19th February 2011 10:32 PM
Lower gain 12AX7? PeteMcK Tubes / Valves 43 12th February 2011 04:49 PM
low gain 12ax7 schematic bakpaosiomay Analog Line Level 19 18th August 2009 11:27 AM
Dead 12ax7 gain stage - Help... mouldiwarp Tubes / Valves 13 22nd March 2009 10:25 PM
