2A3/6A3 tube preamp
2A3/6A3 tube preamp
Old 14th February 2018, 04:52 PM   #11
kodabmx is offline kodabmx  Canada
If you're wanting to use 2A3 because it's DHT I suggest looking at 4P1L in triode connection.
Tube Tester Files - 4P1L
Old 14th February 2018, 06:10 PM   #12
audiowize is offline audiowize  United States
Send a message via AIM to audiowize
There's a lot of nay-saying on this thread, but the 6A3/6B4G is well suited for preamp use. Using a 5-10K attenuator at the output will maximize SNR and reduce the issue of microphonics.
Old 14th February 2018, 06:50 PM   #13
Mr_Zenith is offline Mr_Zenith  United States
Mr_Zenith's Avatar
2A3/6A3 tube preamp
Done.
Hmm KT88 preamp you say... Tell me more
Is an EL34 preamp close enough?
Not trying to be a wiseguy here, but there's nothing really new under the sun.
Old 15th February 2018, 08:52 AM   #14
reellike is offline reellike  Hong Kong
Thank you all your kindly suggestions!
2A3/6A3 tube preampHide this!Advertise here!
5687 tube-based preamp with Tung-Sol Black plates, Sylvana and Phillips ECG tube pair networld Swap Meet 3 10th August 2014 01:23 AM
need diy tube preamp (line-stage) recommendation and general tube advice Musiclover4 Tubes / Valves 16 18th May 2013 03:19 PM
Running a tube preamp into a solid state preamp? Pckid212 Solid State 5 6th January 2013 10:12 PM
Preamp tube SRPP 12AU7 VS preamp tube Aikido 12AU7 = all use rec 6X5GT spiritm2r Tubes / Valves 1 6th March 2011 02:53 PM
Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps Travis Clarke Tubes / Valves 3 16th October 2008 04:52 AM
