Multi tubes amps what effect does each has?
Old 14th February 2018, 05:17 AM   #11
aardvarkash10 is offline aardvarkash10  New Zealand
aardvarkash10's Avatar
ok, single-ended...
1= output 2 = driver (totem pole) 3 = voltage amplifier (2 stages)
"It may not be easy for some to not hear differences, even if they are not there." - Vacuphile,
Old 14th February 2018, 07:18 AM   #12
raybies is offline raybies  Australia
Cool, so would the drivers if changed have a big effect on sound or the output?
Thanks for all your help
opinions are like (‿ˠ‿) everyone has one
Old 14th February 2018, 10:31 AM   #13
DF96 is offline DF96  England
The circuit has both local and global feedback, so changing one working valve for another will have little effect. Tube rolling is for guitar amps, and non-hi-fi audio amps with little or no feedback; hi-fi amps don't need it and don't respond to it.
Old 14th February 2018, 11:50 AM   #14
Lingwendil is offline Lingwendil  United States
Now with high-fructose ASSAULT-gluten!
Lingwendil's Avatar
^ good quick advice.
You can buy some NOS tubes to run in it if You like, Just to get some (maybe) longer life out of better quality valves perhaps, but don't go in expecting any huge difference.
Check out My 6SN7 Push-pull Flea Amplifier project! PCB COMING SOON!
Old 14th February 2018, 11:57 AM   #15
kstagger is offline kstagger  United States
kstagger's Avatar
NOS 12AT7s are cheap - pick up some Tung Sols or RCAs or whatever - no reason to go expensive, and see if they make a difference. It will probably be slight (if any) but at least you don't have a lot of money invested in the experiment.
I'm not a big fan of new 6SN7s - I would try out some GEs which are still inexpensive - at least they will last longer and may have lower microphonics.
300Bs are expensive - even the "bottom barrel" ones and tube rolling here would be pricey. I always used EH Golds = because, at least in the amps I built, they were rugged.
Just wanted to add that's a whole bunch of circuitry to drive a 300B. But I like pentode drivers, so what do I know
Old 14th February 2018, 07:03 PM   #16
Its been said by better than me, but to repeat it in terms an Aussie would understand - there is enough feedback in that design, you could sling a dead dingo's kidney into a tube socket of that amp and barely notice a difference.
Cheers!
Old 15th February 2018, 08:51 AM   #17
12E1 is offline 12E1  United Kingdom
12E1's Avatar
I'll have to try that...
Hold an a mo... No dead dingos around here... Dang!
Old 16th February 2018, 10:45 PM   #18
What do the mA/V hand written values mean? Is higher or lower better?
Old 17th February 2018, 12:08 AM   #19
Eli Duttman is offline Eli Duttman  United States
That's a measure of transconductance. The exact value is less important than the closeness of the numbers. That pair is matched.
Eli D.
Old 17th February 2018, 01:23 AM   #20
Thanks, so if a pair was say 74mA / 5.4mA/V and 74mA / 5.0mA/V would they still be matched?
1st number is inconsequential, while the 2nd determines the matching?
What deviation should there be to have no match?
Thanks... just 10 days in to learning about tube amps.
Multi tubes amps what effect does each has?Hide this!Advertise here!
Real multi room, multi input-multi output audio system for smart home gryzli133 PC Based 3 26th January 2018 04:15 PM
Miller effect on tubes with active load CCS Celsius Tubes / Valves 26 9th February 2017 01:53 PM
SMPS for diy audio amps and multi-channel diy amps (and their power supplies) tlparker Solid State 20 12th May 2015 12:23 PM
Nonstandard tubes for audio? Quadrature grid chorus effect? m6tt Tubes / Valves 2 30th January 2008 08:41 PM
Running power to tubes so as not to effect the audio signal A3rd.Zero Tubes / Valves 7 22nd April 2004 02:07 AM
