transformer based phase splitter
Old 13th February 2018, 01:45 AM   #11
trobbins is offline trobbins  Australia
trobbins's Avatar
Originally Posted by kodabmx View Post
I used Hammond 124B, and I biased it this way because I used individual bias controls for each tube since the OPT was a power toroidal. Using a single voltage for both tubes results in too much imbalance.
Yes, the IT secondary would need to be a split winding terminal format to allow some independent biasing adjustment to be incorporated.
Old 13th February 2018, 06:58 AM   #12
SemperFi is offline SemperFi  Wake Island
Originally Posted by DAK808 View Post
I have this UTC O-6 which has primary 15K into 95K CT secondary. Is this an appropriate trans for phase splitting. If so what kind of tubes would be best suited for this ? I have mostly pentodes and beam pentodes, el84 to kt120 in terms of power output. I also have output trannys to match. Thank you for your suggestions. cheers, 808
Since the IT has low input impedance and steps up, I'd use a medium mu triode such as 6SN7 or 6DJ8 etc. Or how bout trioded EL84s? What mu do they have as triodes?
I've been using EDCORs XSM series as IT and am very happy with them. I do not use feedback around them tho, have never felt the need for GNFB. But thats just me.
Old 13th February 2018, 07:07 AM   #13
Regarding ringing you cant tame...I ignore the square wave tests when using ITs. It sounds so good who cares...
U could modify the IT by desoldering the center tap and getting the secondaries separated. I've done that on EDCOR transformers. Just do it before too many cups of coffee, and fasten the wires to new pins before measuring the results, the wires are so fragile and will break if bent more than a few times. But once they are scured to a pin they are ok to work with.
Then u could do like this:
Old 13th February 2018, 11:38 AM   #14
Lingwendil is offline Lingwendil  United States
Now with high-fructose ASSAULT-gluten!
Lingwendil's Avatar
I've never been satisfied with interstage transformers other than the rare exceptions where I've been fortunate enough to work with very expen$ive iron... They tend to ring even without being wrapped in a feedback loop, and can be a bear to tune at times. I would prefer even a *shudder* floating paraphase splitter to an interstage except in very rare instances, or at line level. Since I no longer have an oscilloscope to tune them, I don't fool with them anymore.
That having been said, they are a period correct way to go for AB2 DHT types of builds, and if you can tame them, they work well.
Check out My 6SN7 Push-pull Flea Amplifier project! PCB COMING SOON!
Old 13th February 2018, 11:49 AM   #15
TheGimp is offline TheGimp  United States
TheGimp's Avatar
SemperFi, on the XSM.
Which transformer are you using, 10K:10K?
Since they are line matching transformers, they are not designed to handle dc in the primary. Do you run the parafeed input?
If there are no dogs in Heaven, I don't want to go there.
Old 13th February 2018, 12:14 PM   #16
martyh is offline martyh  United States
I think a small trafo like the O6 might be better at the input. I would try it into a diff pair. Need to watch input C of the next section though. Might make a tough load for the preamp.
Old 13th February 2018, 12:43 PM   #17
Eli Duttman is offline Eli Duttman  United States
Agreed. I think an ECC99 in the diff. amp will handle just about anything downstream. IIRC, Lynn Olsen did this very thing.
To avoid complications, employ good O/P "iron" and stick to short loop NFB, within each leg. All "iron" will be outside of any NFB loops.
Eli D.
Old 13th February 2018, 03:34 PM   #18
DAK808 is offline DAK808  United States
So, by having the input going to pin 1, p2 to ? . on the secondary the p3 to one tube and p4 to ? then p5 to the other tube. Or both outputs to 2 different sections of a dual triode. You don't happen to know of a schematic of an amp where this type of IT is used as an input splitter.
Old 13th February 2018, 04:11 PM   #19
pieter t is offline pieter t  Netherlands
No.
Lynn used a line level input transformer; all next stages are transformer coupled class A push pull.
Phase splitter transformers at "interstage" level are real nightmares to get right; I experimented a lot.
Measurement wise, line level input transformers using small high permeability cores and without any DC currents through windings are much much better.
Of course some will prefer the "sound" of the inferior interstage phase splitter transformer
Old 13th February 2018, 04:19 PM   #20
As previously stated, Lynn Olson did work along these lines. Look here. Lynn too warns of the very difficult load this sort of circuitry presents to the driving electronics. Use a big, honking, MOSFET source follower running at about 30 mA. of drain current ahead of the phase splitting trafo. The FET will effortlessly charge and discharge the nasty net capacitance, while exhibiting an O/P impedance well under 100 Ω. Remember that trafos are inherently low impedance devices and the low impedance driver will squeeze the best possible linearity out of the "iron".
Eli D.
transformer based phase splitterHide this!Advertise here!
Tribute Line Input Transformer / Phase splitter transformer chrismercurio Swap Meet 3 3rd September 2017 12:25 AM
Fet based phase splitter? danielwritesbac Solid State 94 9th July 2014 03:34 PM
Transformer phase splitter Jaime Tubes / Valves 10 31st May 2010 07:40 PM
K & K Audio Transformer phase splitter? wttaylor Tubes / Valves 0 5th March 2010 09:55 PM
Stereo 7O with transformer phase splitter? wttaylor Tubes / Valves 2 26th February 2010 11:55 PM
