ST-70 with Edcor Transformers
Old 13th February 2018, 09:36 PM   #31
H713 is offline H713  United States
Originally Posted by Eli Duttman View Post
As for the 6L6 family tubes, check out the 6L6GC, 7581, and KT66 datasheets.
Never realized the KT66 drew that much heater current. Hmm. Is there a reason we see more production HiFi amps with EL34s than 6L6s?
Old 13th February 2018, 09:50 PM   #32
20to20 is offline 20to20  United States
.... Compared to...?
Old 13th February 2018, 10:29 PM   #33
6L6GC, 7591.
Old 14th February 2018, 12:26 AM   #34
Ok. The thread started with plans for an ST-70 ish design. The EL34 would pull .2A each more than a 66. Good luck with your project.
Old 14th February 2018, 01:28 AM   #35
I found this design by Jason Thorpe over on Audiokarma (really sorry to link to another forum, got to give credit to the guy though). It looks quite similar to the Mullard design though, and it uses the 10M45 current regulator. This looks a lot like what has been talked about earlier in this thread (though it uses 6L6s). Again, this is NOT my design.
This is the Audiokarma thread:
Looking for schematic for nice clean push pull 6l6 monoblock | Audiokarma Home Audio Stereo Discussion Forums
Old 14th February 2018, 05:36 AM   #36
Eli Duttman is offline Eli Duttman  United States
Mr. Thorpe used Mullard style circuitry along the very lines I've been talking up. There are a few details to change and nits to pick [of course ], but that's the basic signal topology to use. Jason successfully connected the LTP "tail" to ground. I want that "tail" connected to a small negative voltage, for "elbow room". Remember, PSUs are at AC ground.
The B+ topology is pretty much what we'll use. As you're finding out, there is very little new under the sun, when it comes to tubed circuitry. IMO, the big advance has been the ease with which constant current techniques can be implemented. Way back when, constant current implementation was such a PITA that nobody bothered. Solid state (SS) items, AKA "sand", frequently make good "spear carriers" for tubes.
Cross linking between "boards" is commonplace. An apology was not necessary.
Eli D.
ST-70 with Edcor TransformersHide this!Advertise here!
Edcor Transformers whitelabrat Tubes / Valves 23 9th September 2011 02:16 AM
EDCOR XSM 10K/10K Transformers wushuliu Swap Meet 3 15th January 2011 07:24 PM
FS: 2 Edcor CXPP100-MS-3.3K transformers rsumperl Swap Meet 1 21st October 2010 12:47 AM
Edcor Transformers Sal Brisindi Tubes / Valves 18 11th November 2007 01:08 PM
Edcor P-P Transformers wrenchone Tubes / Valves 10 30th June 2006 07:01 PM
