6J1 preamp
6J1 preamp
Old 11th February 2018, 09:30 PM   #11
Ketje is online now Ketje  Belgium
Ketje's Avatar
Originally Posted by adason View Post
Great, thanks Ketje, will test all.
I thought that R16 was only drawn incorrectly in the schematics, but in reality was ok. Will check that out.
If it's only in the schematic, no problem then.
Well, i am already using two separate trafos, so i got that already on my own.
The two times 12V is not two trafos, simply a 24V with center tap.
Mona
Old 12th February 2018, 12:40 PM   #12
adason is offline adason  United States
adason's Avatar
Ketje, I understand perfectly what your picture shows...
I was describing what I did, not that any one cares. I use two separate adapters to power it. One 12 DC adapter just to power the heaters. One separate AC adapter to power the voltage multiplier. This way I can swap the AC adapter with increasing voltage, I use 18 volts AC now, giving me +/- 48volts volts for tubes. Sounds better this way, then measly +/- 28 volts.
I will be beefing up some filtration here and there, but otherwise I am almost done with it. No need to waste time on cheap project.
Old 13th February 2018, 06:08 PM   #13
kodabmx is online now kodabmx  Canada
Or you could use one of these and have dial-a-volt
DC-DC 8-32V to +-45V-390V Step-up ZVS High Voltage Capacitor Module Charge Board | eBay
Old 14th February 2018, 02:17 AM   #14
adason's Avatar
Thanks for the suggestion kodabmx.
Minor issue is that i have already replaced original caps rated 35 volts to new ones for 50 volts. Therefore i do not want to exceed 100 volts total right now.
Thanks anyway.
Old 14th February 2018, 10:55 AM   #15
Ketje's Avatar
You can also get more voltage without an extra transfo.
Mona
6J1 preampHide this!Advertise here!
Viking RP61 tube preamp into Mic preamp? Magnetmaz Instruments and Amps 1 7th April 2015 08:47 PM
Running a tube preamp into a solid state preamp? Pckid212 Solid State 5 6th January 2013 10:12 PM
Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps Travis Clarke Tubes / Valves 3 16th October 2008 04:52 AM
twisted pear Preamp/other suggestions for Preamp kit LukeDuke Chip Amps 1 1st February 2008 09:57 PM
Electret mic preamp - will phono preamp work? darthmullet Analogue Source 6 12th October 2007 07:32 AM
