6P41s vs 7868
6P41s vs 7868
Old 9th February 2018, 09:29 PM   #21
davorin is offline davorin  Croatia
Originally Posted by Kay Pirinha View Post
Are there available any datasheets for these 6P41S? Frank doesn't appear to have them handy...
Best regards!
Original files:
Some curves:
Old 10th February 2018, 09:03 AM   #22
Kay Pirinha is offline Kay Pirinha  Germany
Kay Pirinha's Avatar
Originally Posted by davorin View Post
Some curves:
Thanks, Davorin!
Now I'm about to find someone to teach me the Russian language .
Best regards!
"Bless you, Sister. May all your sons be bishops." (Brendan Behan)
Old 10th February 2018, 04:19 PM   #23
artosalo is offline artosalo  Finland
artosalo's Avatar
I intend to try the 6P41s some time to see what I can squeeze out of them.
I done some tests with 6P41S as a PP-amplifier. Here are results with 40% UL, triode connected and pentode connected with different operating conditions.
Attached is also the schematic of the test circuit. All measurements were done without GNFB.
Old 10th February 2018, 04:33 PM   #24
huggygood is offline huggygood  France
good ! i have a pair of hammond 1560 in my stock
Old 14th February 2018, 10:14 AM   #25
i received my 7591 quad
I'm waiting for my octal socket
to be continued ...
Old 2nd March 2018, 10:01 PM   #26
cags is offline cags  United States
Hello Toprepairman,
I am in process of a total restoration to convert Rowe R-4359 amp to use as a stand alone audio amp for my sound system. Am searching for parts list and schematics. I have come across of schematic by secret4mula but not clearly readable. Any info you can assist me with will be greatly appreciated. Would you know the manufacturer of the output trannies? Thanks again .
Joe
Old 4th March 2018, 01:05 PM   #27
toprepairman is offline toprepairman  United Kingdom
Hi Joe.
Like you I only found a poorish copy on the net and then redrew it by hand.
I really don't know who made the transformers. I have stripped out the surplus wiring with the relay etc, with a view to converting to a straightforward stereo amp.
I got a set of 6P41's but they don't really perform as the originals so I may remove the bases and fit octals to run with 6L6/5881 type valves.
I'm not sure when I'll get round to doing this as I have another, bigger, more pressing project on the go in the shape of a house rebuild. Currently I'm looking at a big hole in the ground with a load of concrete in it. Behind is a huge pile of clay that came out of the hole so this is taking priority just now.
Henry
Old 4th March 2018, 01:40 PM   #28
Charm is offline Charm  Russian Federation
Thanks, Davorin!
Intelligence reported, the analog is EL508, PL508..
Old 16th April 2018, 05:53 AM   #29
I just picked a ami-rowe 4359A but with missing preamp and missing tubes ...
Old 1st May 2018, 08:01 AM   #30
ok,the 6p41s are definitely different to 7591/7868
on my AMI-ROWE r4359, I got to get -70vdc for bias and+ 380vdc for a supply voltage and it's still not good,
the 6p41s do not work long at this voltage.
I start the conversion for 7591.
I keep the 6p41s for a future low voltage amp
end of episode 6p41s
6P41s vs 7868Hide this!Advertise here!
The SE UL 6P41S USSR jean michel Tubes / Valves 20 29th December 2014 06:33 PM
Sockets for 6P41S quikie22 Tubes / Valves 2 31st July 2011 09:11 AM
WTB: 7868 tubes DSummer Swap Meet 1 21st July 2011 04:47 AM
Using the 7591 or 7868 andyjevans Tubes / Valves 11 21st June 2010 04:53 AM
Headphone amp with 6P41S Pentium100 Headphone Systems 4 4th April 2006 08:11 PM
