Can someone explain damping factor
Old 9th February 2018, 06:02 PM   #41
traderbam is offline traderbam  Europe
traderbam's Avatar
Well, in general, at lowish frequencies, the NFB factor divides the size of the open loop output resistance at the point the NFB is taken from.
Eg: 15dB of NFB is about a factor of 6. If the OL output resistance at the point the feedback is taken from is 6 ohms then after applying 15dB of NFB you would expect the output resistance to be 1 ohm.
Everything matters.
Old 10th February 2018, 11:38 AM   #42
DF96 is offline DF96  England
Which is why I said in an earlier post that you can't directly go from NFB to DF, yet the OP still seems to be asking for this.
Old 10th February 2018, 12:11 PM   #43
MEPER is offline MEPER  Denmark
What is the definition of an X ohm output on a OT?
When an OT has a e.g. 4 and 8 ohm output what makes the 8 ohm output an 8 ohm output? .....the DC resistance is much less than 8 ohm I assume. Is it measued at a specific frequency?
Old 10th February 2018, 02:02 PM   #44
hpeter is offline hpeter  Slovakia
hpeter's Avatar
alt+0181
BLOG. XMOS_U8/PCM5102A > LL1544A > 6H9C+gyrator > 2A3_SOV/JJ > LL1660 > STAX SR207 _ SR L300 _ SR007 # LL2748 > 394A > LC 12H/1000
Old 10th February 2018, 02:05 PM   #45
hpeter's Avatar
bassreflex is "standard" these days, but it is more or less distortion + headache inducing technology.
thankfully ear is not sensitive to distortion at bass
open baffle people may agree that their stuff is cleaner and better
Can someone explain damping factorHide this!Advertise here!
Damping factor Cro maniac Chip Amps 43 4th August 2015 02:09 PM
Damping Factor hartze11 Tubelab 12 3rd October 2011 02:13 PM
What is SI T-Amp DF (damping factor)? skrstic Class D 1 23rd April 2008 09:49 PM
Damping factor thylantyr Solid State 9 14th March 2003 06:37 AM
Damping factor..????? emarald Solid State 15 30th January 2003 02:41 PM
