Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Tubes / Valves All about our sweet vacuum tubes :) Threads about Musical Instrument Amps of all kinds should be in the Instruments & Amps forum |
#11 |
frugal-phile(tm)
Damping factor is a very misleading spec and not nearly as useful as knowing the output impedance (Z(source), the speaker impedance (Z(load)) and how well damped the LF alignmnet of the speaker is.
There is an appropriate output impedance for any speaker. Most modern commercial loudspeaker is designed assumming a low output impedance (ie voltage source), but in the diy world we have a lot more choice. Since a speaker is driver is a current controlled device (not a voltage controlled one) there are advantages to amplifiers with high output impedance (current amp). What is appropriate in the amplifier is very much dependent on the speaker to be used with it. They should not be considered separately. dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#12 |
This article may have the answers to your questions, noted the effect on frequency response of various damping. Once you have determined the critical damp factor of the speaker then you can adjust NFB for amp to lower or raise output impedance to match the critical damping so that the frequency response becomes flat. The output impedance of the amp and speaker damping factor need to be found out separately of course.
#13 | |
#14 | |
One could roughly model the speaker as having an ideal zero-resistance coil (e.g. made of superconducting wire), in series with a resistor R(load). The measure of how well damped it will be is then given essentially by Z/R(tot), with R(tot)=R(load)+R(source), and Z being the impedance (highly frequency dependent) of the superconducting coil in its dynamical environment as it moves, on the speaker cone, in the magnetic field of the speaker magnet. I just measured the DC resistance of one of my Lowther DX3 speakers, and it is about 7 ohms. Looking at the impedance plots for the DX3 there is a huge peak, of order 100 ohms or more, at about 60 Hz. Outside the range 30 - 130 Hz, the impedance is about 10 ohms or less. So outside the 30 - 130 Hz range, the resistance of the coil accounts for most of the impedance of the speaker. This means the "true" damping factor over most of the audio range will never be more than about 2 at the most, even if the source has virtually zero output impedance. And whether the source has 0.01 ohms or 1 ohm output impedance hardly affects the damping at all. |
#15 |
Get a solid state amp (it has oodles of damping factor). Now add some resistance in series with the output, and listen. Do you like the sound? Try a different value. Eventually you will find a value that suits your speakers and your ears, and you can try to emulate that value in the next amp you build.
#16 |
On high powered subs about as high a df as you can get.
(at least 300, better 500 - 2000+). Use "thick wire" also. Some will say it doesn`t matter but clearly they didn`t experiment themselves.
#17 | |
“Simplicity is the ultimate sophistication.” Leonardo da Vinci Last edited by traderbam; 8th February 2018 at 08:47 AM. |
#18 |
Thanks Koonw, that's a very interesting article that actually answers the question
Woofer Assisted Wideband is the New Testament ![]() |
#19 |
#20 |
I am missing measurements of group delay, distortion and impulse response in that article.
FR alone isn`t telling the whole story.
Thread | Thread Starter | Forum | Replies | Last Post |
Damping factor | Cro maniac | Chip Amps | 43 | 4th August 2015 02:09 PM |
Damping Factor | hartze11 | Tubelab | 12 | 3rd October 2011 02:13 PM |
What is SI T-Amp DF (damping factor)? | skrstic | Class D | 1 | 23rd April 2008 09:49 PM |
Damping factor | thylantyr | Solid State | 9 | 14th March 2003 06:37 AM |
Damping factor..????? | emarald | Solid State | 15 | 30th January 2003 02:41 PM |
New To Site? | Need Help? |
