| diyAudio Sponsor | ||
I have a couple of 12AX7LPS tubes, plan make a preamp.have what propose?
#2 |
Get different tubes.
#3 |
What type of preamp? Phono or a basic system control preamp.
Frank |
#4 |
These days when people say preamp they mean line stage. The 12AX7 is probably suitable for phono duties but quite pointless in a line stage.
#5 |
thanks for reply
I plan to make a line stage,A lot of friends around me say that 12AX7LPS are adjusted very badly,but the sound is very fine,very warm. This is my sch,any suggestions? |
#6 |
diyAudio Senior Member
The cap after the 6X4 is really high, about 10µF should be a lot safer. Cheers,
Frank |
#7 |
sure,thank you.
-digi |
#8 | |
Enjoy! Wayne
#9 |
Personally, I would go for the 6SN7gt, or the 6SL7gt if you need that extra gain, the 12ax7 aint a great valve, a bit prone to microphonics, Changed dosens of them over the years!
The 6sn7/6sl7 have a great reputation it seems, but they are an International Octal 8 pin, and benefit from DC heaters to reduce injected hum, especially in phono stages!
Das Beste Oder Nichts |
#10 | |
can i use 6sn7 for phono stage & 12ax7 for line stage? isak0411 |
| 2x 12AX7 preamp fuse value | gottlieb | Tubes / Valves | 7 | 18th May 2009 04:29 AM |
| 12ax7 preamp. | longji98 | Tubes / Valves | 20 | 13th September 2008 06:06 AM |
| Looking for a Balanced Mic Preamp w 12AX7 | Ahmad_tbp | Tubes / Valves | 4 | 7th February 2007 12:01 PM |
| 12AX7 preamp project | Mrpong | Tubes / Valves | 0 | 24th January 2006 12:47 PM |
| 12ax7 preamp | Antonix | Tubes / Valves | 4 | 17th November 2005 03:52 PM |
| Page generated in 0.17956 seconds (59.68% PHP - 40.32% MySQL) with 11 queries |
