you wanted to get the AB-Q module connected to amplifier with 6GH8 and 6CZ5 tubesHello Everyone, I need some advice please. I have a Knight Kit Stereo 40, KA-55 Amplifier that is trashed. I want to use the Power and Output transformers for this project if feasible. The first RCA schematic comes up in a few places on line. The second schematic also shows up on the net and has a few voltages attached that some seem incorrect in the power supply. Also attached is an ultra linear set up from a Seeburg jukebox amp that uses the same value resistors for the 7199 tube as the rca schematic shows. What I want to do is use 6GH8 and 6CZ5 tubes in this amp and use it as a power amp. I started working on a schematic according to the Sylvania 6CZ5 tube data sheets and what I have on hand around here. Please be kind, this is my first project and I am stumped as to if this will even work. I have rebuilt several amps in the past. Thanks, Tom
Pavel
The auto bias board will not work for me. I will have right at -24.65v at 10k with nice, even, steady negative voltage. I think that will work fine to get the -23.5v or whatever I need (if) I did this correctly. Please see schematic. If not please tell me. Also attached are a couple naked pictures of what I am working with. I will mount the choke where the 115v receptacles where. Thanks
I have to oppose it. We sold hundreds of them and there are no complaints.I'm dubious about automatic bias boards. They may be OK, but I'm dubious. Setting things manually, on a periodic basis, is well known to be reliable.
If someone complains, they can not skill connected them.
Pavel
pavlikkkk,
I am new here. I am an amateur trying to learn. I contacted you privately through this site and Ebay, I told you my parameters. I do not have enough voltage to run your board. Why do you want an explanation of an opinion where your board clearly will not work. then you post the wrong schematic. You have forum threads of your own on this subject. I don't need a salesmen when what I need really need is help with my project which you have knowledge of and could help offer a solution. Think about it before you hijack a thread again for your own personal gain.
