DIY transformer and two-component epoxy adhesive
Old 14th February 2018, 09:11 AM   #31
Elerion is offline Elerion  Spain
Originally Posted by SemperFi View Post
What is the primary inductance? Is the magnitization (primary idle) current pretty high?
Are all the inductances as expected? Could a winding be the wrong way as to work against some of the other?
I don't think any windings is working against other.
B+ supply, bias supply and filament supply are all perfect, in terms of voltage. I use this PT in a real SEUL/SET amplifier, and it sounds great (probably my best sounding amp).
I measured the inductances (primary and also leakage) when I built it, and it seemed ok to me.
I'll measure it again today and post the exact value.
The idle current is something close to 90 mA (the amplifier is a monoblock). But, as already mentioned, the buzz is still there even when no loading at all.
There's some window height available (probably around 2 mm), and I'm using a split bobbin [primary/shield/bias] on one side, and [HV sec/filament sec] on the other.
I could unwind the top windings, and add some more turns to all, to lower the magnetization... but I probably won't get below 1.1T.
Of course this is quite a bit of work, so I was trying to avoid that if possible.
Old 14th February 2018, 11:44 AM   #32
Originally Posted by TonyTecson View Post
like so....
Nice finish
Old 14th February 2018, 05:23 PM   #33
Primary inductance is 5 H at 100 Hz.
Would you un-wind and try to add some more turns?
Probably I would only be able to get 1.2T or little less.
No much winding window left.
Old 16th February 2018, 08:05 PM   #34
So, enough talk. This required work
I unwinded and added 76 more primary turns.
Magnetization should have drop to 1.2T.
I've put everything together again, and after some hours of careful work , I just tested it, and...
Partial success.
It's still buzzing, but it seems to be a bit more quiet.
Perhaps 5 dB less (according to a crude sound meter app run on my phone, just next to the core, with the same exact mounting and on the same surface).
Now I need to be close to it to be able to hear it clearly.
I even have some winding window left,... maybe I could get down to 1.15T, but unwinding it again is something I just can't think about right now
As a curiosity, I measure the magnetic field before and after the modification.
At 30 cm, it was above 2mT from the front, and about 1.2mT from one side.
Now, it is lower. 1.6mT from the front, and 0.85mT from one side.
I suppose this makes sense.
I'm still using the same stiff 1.4mm wire for filament winding. I wanted to play with a single variable at a time. I could try to replace it with bifiliar 1mm. But many hours seem to be required to get a perfect result (at least two more times taking aways the laminations, and putting them back together )
Old 16th February 2018, 09:26 PM   #35
SemperFi is offline SemperFi  Wake Island
Good job keep it up. It will be interesting to see your conclusion to what was required to reach your satisfactory xfrmr.
Old 16th February 2018, 09:28 PM   #36
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
i operate on a 0.6 to 0.8T in my tube power traffo builds, even for the higher quality cores, i seldom went beyond 1Tesla...
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 17th February 2018, 08:35 AM   #37
Before this one, I made a small PT for a preamplifier, with regular non-GOSS laminations, at 1 Tesla. It is quiet. So for this bigger one, being GOSS, I felt confident, so I targeted to 1.4 T.
Even at two meters distance, in complete silence, I can hear the buzz clearly.
It is not very annoying, but it is there, so I'm going to try to improve this further.
I'm testing the transformer like shown in the picture. No bells, no wedge, no pads. Just four bolts and those metal pieces (which I don't know their names in English) to make pressure along the short laminations sides.
Could a bad electrostatic shield or not perfectly insulated bolts make the transformer buzz? I think I've done it right, but just to know.
Old 17th February 2018, 09:09 AM   #38
TonyTecson's Avatar
if your electrostatic shield shorted out, you will see smoke come out....
otherwise no worries....
Old 17th February 2018, 09:16 AM   #39
TonyTecson's Avatar
@Elerion, i am looking for a plastic bobbin similar to yours, 2.25 inch center leg and 4 inches stacking height, do you have them in your place?
Old 17th February 2018, 09:39 AM   #40
@TonyTecson, what a HUGE beast!
What EI size is that? EI-171?
I can get EI-150 and EI-180, and I think EI-174 (5,8 cm center length, which is a little bit bigger) but that one I need to ask. Is this one OK for you?
For EI-180 there're bobbins for up to 12 cm stacking height, so probably there will be bobbins the height you need. Just tell me if EI-174 is good for you, or not, let me ask, and I'll come back with some news in several days time.
DIY transformer and two-component epoxy adhesiveHide this!Advertise here!
Transformer epoxy or fill for diy potting Masonstorm Power Supplies 11 16th January 2018 04:48 PM
adhesive/epoxy for the amp nonprof Car Audio 11 2nd September 2015 06:09 AM
Conductive epoxy john dozier Parts 18 30th December 2010 05:30 AM
Epoxy or PVA Mos Fetish Multi-Way 2 4th February 2006 10:57 PM
Audio Note DAC KIT1.2 component list and power transformer spec PTSOUNDLAB Digital Source 2 13th May 2003 06:55 AM
