I am theoretically examining the behaviour of the filament of a 6AS7G tube during a slow turn-on.
I'd like to know the current into the filament for some applied voltages. I only know the current when the filament is completely cold and when it's completely hot. By chance, do you know such data? Or do you know a right approach to the question? GF |
#2 | |
Isnīt it possible to messaure it with a multimeter? |
#3 |
diyAudio Moderator Emeritus
If you look at pages 269-271 of "Valve Ampifiers" 3rd Ed. Morgan Jones, you will find a full test methodology and results that should answer your question.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#4 | |
diyAudio Senior Member
Would it come up slower. Would the bulb last longer? Cheers,
Frank |
#5 |
My understanding is that thorium was added to the tungsten filament in lightbulbs to make it more ductile (more easily drawn through the die to form the fine filament wire) and that increased emission was a secondary effect. I've seen valves that flash like light lightbulbs at switch-on (to reduce warm-up time), but I've never seen any that are deliberately slow. Conversely, the only lightbulbs that are slow are the ones with thick filaments. As a kid, we found that it was a waste of time connecting the sound-to-light* stage effects unit to 500W lamps, but it was very effective when connected it to a batten carrying a dozen 60W domestic bulbs.
* We bought the sound-to-light (with school money) as a ready-built PCB, put it in a box, and connected it to the mains. It blew up once (we overloaded it) but we replaced the triacs. All as school kids...
#6 | ||
Remember the "A" suffix on US small signal valves? Apparently this A was to indicate the presence of such a coated heater. Whether it was actually slower, I very much doubt. The main reason I think was to appease users as they were worried by the flash as it resembled a miniature lighting show inside their table radios when switched on. They were probable convinced something was wrong with the valves... The reason is simple, what you see is actually a part of the heater sticking out of the cathode sleeve. If you coat that part away it won't be visible anymore and everyone's happy. Quote:
All hanging from the ceiling at my parents loft which I occupied during adolescence and gradually turned into a mini disco. Cheers,
Frank |
#7 | ||
#8 | |
Ryssen, I wrote "I am theoretically examining" to say that I don't own that tube so I can't perform measurements. GF |
| 6as7g Se | croccodillo | Tubes / Valves | 15 | 18th June 2008 08:54 AM |
| 6AS7G Grid Voltage ?? | Zero Cool | Tubes / Valves | 2 | 23rd May 2008 08:04 PM |
| 6080 / 6AS7G power amplifier | cjng74 | Tubes / Valves | 1 | 16th September 2007 01:17 PM |
| Parallel vs. series filament supply - or another filament idea | engels | Tubes / Valves | 11 | 13th May 2007 01:06 PM |
| 6AS7G with grid current? | Wavebourn | Tubes / Valves | 1 | 16th November 2006 11:22 PM |
