Old 9th April 2004, 06:52 PM   #21
Default Yes Sy
Might call it a constant (although no tube is perfect). u=gm rp shows that, help our newbie friends. If we can keep u and gm constant, then rp will remain the same and the load lines in quadrant 1 would look great, quadrant 3 transfer characteristics would also be a straight line. Both would have great significance.
By contrast, typical tubes, and more revealing, variable mu or remote cutoff pentodes are variable in that all three parts of the formula are changing because of design considerations of the tube. Any good tube manual will explain the processes envolved if one wants to delve more deeply into it.
Anyway, back to work.
Good info to bring up Sy. Thanks and take care.
Steve
Old 9th April 2004, 07:00 PM   #22
diyAudio Senior Member
fdegrove's Avatar
Varying the grid wire pitch is what triggers the variable mu.
Frank
Old 9th April 2004, 07:15 PM   #23
DrDeville's Avatar
Originally posted by EC8010
Hello, thoriated. But can you afford probes that maintain that 500MHz bandwidth to the probe tip? (I can't.)
As Frank says, grid-stopper values are heavily dependent on layout. I recently had to resort to 10k on a point to point layout (great for audio, less great for RF), whereas the PCB equivalent got away with a few hundred Ohms...
Hi EC,
So how do you select your grid-stopper values? By ear, scope, both?
Thanks for an interesting discussion.
Best,
George Ferguson
Old 10th April 2004, 12:26 AM   #24
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Good question. Both. My oscilloscope claims 300MHz bandwidth at its input BNCs, and the (original) probes claim to extend that bandwidth to the probe tip, but a few pF can make a huge difference to a circuit that's on the edge of oscillating at 100MHz. Fortunately, circuits that oscillate at more than 100MHz tend to be affected by anything that contacts them, and if you listen to their audio output whilst touching them with a probe (or even the blade of an insulated screwdriver) they tend to make more crackles and pops than you would expect, and that can be a pointer that something nasty is going on that your 'scope can't quite see.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 10th April 2004, 06:48 PM   #25
Hi, ec8010 -
Sorry for the delay in responding, but the scope probes I used came with the 500Mhz scope, so I presume they're good for the full bandwidth.
Detailed plans for 206, 207 or Jordan johnb Full Range 31 8th August 2010 11:18 AM
Where can I get a detailed descriptiong of PWM in Class D xuhaoz Class D 0 1st November 2006 08:00 PM
Fast and detailed midbass unit Rocky Multi-Way 35 22nd May 2004 07:35 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
