First Try on Tube Preamp - diyAudio
Old 7th April 2004, 07:54 AM   #1
s2kov is offline s2kov  Canada
s2kov's Avatar
Default First Try on Tube Preamp
Ok this is my first try for tube preamp, your opinion on the circuit will be highly appreciated.
Below is my operating point for 12AU7 twin triode connected in parallel:
Plate Voltage = 185V
Plate Current = 7.75mA
Grid Voltage = - 6V
Thanks in advance....
Old 7th April 2004, 09:00 AM   #2
s2kov's Avatar
BTW, i need your expert opinion with the circuit if i'm getting right with the values indicated and getting the right track.
Am i really on the right track?
Old 7th April 2004, 10:44 AM   #3
hi
How load resistance is expected for that
stage?
Federico
Old 7th April 2004, 10:53 AM   #4
Frank Berry's Avatar
You might get better performance by using a 180 ohm resistor and a 47ufd capacitor on each cathode rather than connecting both cathodes together.
That will eliminate the "current hogging" that can occur if the triode sections aren't matched.
Frank
Old 7th April 2004, 11:05 AM   #5
JojoD818's Avatar
Kabayan s2kov!
I see you are using 12AU7, the foreplay preamp of bottlehead uses 2 of those. Unfortunately, I think it is copyrighted so no DIY!
JojoD
Old 7th April 2004, 11:25 AM   #6
Bottlehead is a simple common cathode stage followed by a cathode follower. Direct coupled between stages.
Frank
Old 7th April 2004, 11:51 AM   #7
s2kov's Avatar
Federico,
I'm using Dynaco ST70 and if i'm not mistaken input impedance is 470K.
Regards.
Andy
Originally posted by fscarpa58
hi
stage?
Federico
Old 7th April 2004, 04:07 PM   #8
Hi s2kov,
Yes, your working point is o.k.
if you want less distortion try 15k at anode
and 200 at cathode. You still have 5V peak to peak before
saturation. Gain will increase of 1.8 db. But output res will rise from 2.5k to 3.2k OHm.
Speaking about output res it seems quite high.
I will consider the use of an output buffer or of an SRPP stage.
...by using a 180 ohm resistor and a 47ufd capacitor on each cathode...
if res and caps as to be put at each cathode (advisable thing) the value of res has to be doubled and the value of caps halved to retain the original characteristic.
Bye
Federico
Old 7th April 2004, 04:25 PM   #9
s2kov's Avatar
Hi Federico,
Thanks for the help! Actually, operating point for each section of triode tube, Rp is 15K and Rk is 744 ohm. Since the design is connected both halves in parallel, Plate current will become 15.5mA (7.75mA + 7.75mA) thus, Rp = 7.5K and Rk = 372 ohm
Is it right?
How did you get 200 ohm for cathode resistor?
Andy
Old 7th April 2004, 06:28 PM   #10
JojoD818's Avatar
How I wish I have a schematic
need diy tube preamp (line-stage) recommendation and general tube advice Musiclover4 Tubes / Valves 16 18th May 2013 04:19 PM
FA: Eico HF-85 Tube Preamp & HFT-90 Tube Tuner joe-electro Swap Meet 0 31st May 2009 05:14 PM
Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps Travis Clarke Tubes / Valves 3 16th October 2008 05:52 AM
tube preamp using submini tube unclejed613 Tubes / Valves 11 19th August 2007 08:14 PM
Is it possible to get "tube sound" with just a tube preamp and chipamp output? Spasticteapot Instruments and Amps 43 15th May 2006 06:28 PM
Copyright 1999-2017 diyAudio
