First Try on Tube Preamp - Page 4 - diyAudio
Old 21st April 2004, 08:26 AM   #31
JojoD818's Avatar
arnoldc,
I'm almost finish with soldering and other stuffs.
Old 21st April 2004, 08:31 AM   #32
JojoD818's Avatar
I have installed the tubes... checking connections...
Old 21st April 2004, 08:38 AM   #33
Frank Berry's Avatar
Beautiful workmanship.
Congratulations!
Frank
Old 21st April 2004, 12:29 PM   #34
JojoD818's Avatar
Congratulations!
Thanks Frank! It's alive!
Used a GC amp for testing.
Ohlala!
JojoD
Old 22nd April 2004, 12:04 AM   #35
s2kov is offline s2kov  Canada
s2kov's Avatar
JojoD,
Is it already the circuit you're looking? Nice one again! Is it possible if you can share it with me?
Old 14th May 2004, 12:52 AM   #36
s2kov's Avatar
I just finish to built my own preamp and i want to tweak it to further improve the sound of my ST70.
Can anyone recommend what value of coupling cap that will be used to match the ST70? Is the input impedance of the amp is the resistor connected in parallel with the input of the amp?
Thanks....
Old 14th May 2004, 01:03 AM   #37
diyAudio Senior Member
fdegrove's Avatar
Yes, that's one way of putting it...
I think the stock ST70 had 100K input impedance so a 0.470F coupling cap should do, depending how low you want it to go.
Frank
Old 14th May 2004, 02:38 AM   #38
s2kov's Avatar
Thanks Frank....
need diy tube preamp (line-stage) recommendation and general tube advice Musiclover4 Tubes / Valves 16 18th May 2013 03:19 PM
FA: Eico HF-85 Tube Preamp & HFT-90 Tube Tuner joe-electro Swap Meet 0 31st May 2009 04:14 PM
Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps Travis Clarke Tubes / Valves 3 16th October 2008 04:52 AM
tube preamp using submini tube unclejed613 Tubes / Valves 11 19th August 2007 07:14 PM
Is it possible to get "tube sound" with just a tube preamp and chipamp output? Spasticteapot Instruments and Amps 43 15th May 2006 05:28 PM
Copyright 1999-2017 diyAudio
