TEK found that the tubes in the vertical amps of their 540 scopes had a problem called 'interfacing'.
A layer of material formed under the outer layer of emitting material, in circuit it looked like
a poor conduction layer in parallel with a capacitor under the surface.
The problem was fixed using 6DK6 tubes, my recollection there were 12 of those in the vertical amp.
The amplifier in this case is a PP Distributed design, something we won't find in audio.
But there could be tubes, both new & used that might have the 'Interface' problem.
There are certain cathode nickel formulations that are specified to avoid this problem.
I had quite a few Tek scopes, and later models switched to industrial variants of 6DK6.
http://www.tubebooks.org/Books/Atwood/Tomer 1960 Getting the Most Out of Vacuum Tubes.pdfhttp://www.tubebooks.org/Books/Atwood/Tomer 1960 Getting the Most Out of Vacuum Tubes.pdf
(It's not really a serious academic book, take what it says with a grain of salt)
URL from my post #38 are wrong - here we gohttp://www.tubebooks.org/Books/Atwood/Tomer 1960 Getting the Most Out of Vacuum Tubes.pdf
All I can find is a TDS540 scope which has no valves in, AFAIK. Interesting phenomenon though which I'll look into. Also are you referencing direct coupled vertical amps?TEK found that the tubes in the vertical amps of their 540 scopes had a problem
A few posts crossed there, thanks all.
