Hello All.
I'm new to this forum and also pretty new to the tube world so please forgive me for the very broad question that I am about to ask. I have a Harmon Kardon A224 Integrated Amp that badly needs updating (caps and resistors) but is still operational. I was thinking that with the needed reworking, and my desire to never leave things alone, maybe I would be better off to use this as a donor to build a little more up to date amp without all of the excess, unnecessary controls. In case you are unfamiliar with the 224, the unit has 3-12ax7, 2-12au7, a 5AR4 rectifier and a quad of EL84's. And finally for my question: Should I just replace caps and resistors and leave it be or should I turn it into a donor? If I should use it for a donor, Any interesting ideas/links on what to do with it? Thanks for bearing with me. |
#2 |
I'd go for a rebuild. Those old HK amplifiers were highly rated.
Make sure you replace the electrolytic caps in the power supply before you do anything else. Have fun and let us know how it sounds when you finish.
Frank |
#3 |
I also have an H/K 224 and I use it with my old Garrard Zero. It's a nice amp and if I were you, I'd rebuild it. The caps and the resistors are readily available.
I'll try to post the schematic diagram of the amp as soon as I find it. Cheers. |
#4 |
have seend the internal build, its on a copper plate and all the parts also appear in good condition. any special care needs to be taken , before i power on
Rajesh |
| Donor DVD player for DIY project | smallangryboy | Digital Source | 3 | 29th December 2009 11:08 PM |
| Which TT do I use as a donor for DIY TT? | G | Analogue Source | 1 | 13th September 2004 04:43 AM |
