Voltage Doubler Problem
Old 7th April 2004, 05:16 AM   #11
thoriated is offline thoriated  United States
Hi, Runeight -
Is 50mA the transformer's rating at 240VAC? If so, perhaps its secondary voltage peaks are being flattened when the 23mA load is applied which will show up as a loss of regulation. Is the 23 mA passing through the 5.1K before the point where the output is measured? That could result in 100 + volts of drop, also.
I used a HW circuit to get a bipolar output supply in the early days of my OTL amp but I probably pushed my luck a little bit when I used one of the dual primaries of a 1400VA toroid kit to do so
Voltage Doubler ProblemHide this!Advertise here!
All tube voltage doubler Steven-H Tubes / Valves 16 8th July 2011 01:02 PM
Need help with voltage doubler Lingwendil Power Supplies 6 22nd April 2009 01:15 AM
Voltage Doubler jwatts Tubes / Valves 3 2nd January 2009 01:13 AM
Voltage doubler question Ryssen Power Supplies 25 14th October 2006 07:22 PM
Voltage doubler Baard Solid State 28 17th January 2005 05:46 AM
Copyright ©1999-2017 diyAudio
