211SE with 14K Trs
211SE with 14K Trs
Old 13th January 2018, 02:39 AM   #1
L CAO is offline L CAO  China
Default 211SE with 14K Trs
With 211 tube made a single-ended power amplifier, the use of a 14K impedance of the output transformer, so you can not loop negative feedback.
Old 13th January 2018, 04:12 AM   #2
EF91+5686+211
Old 13th January 2018, 06:24 AM   #3
EF91 & 5686 are triode connected.
Old 13th January 2018, 07:00 AM   #4
Test Results:
1 watt output frequency response:
8 ohm 10 watt output frequency response:
Output power VS distortion:
FFT:
Old 13th January 2018, 07:25 AM   #5
211 operating point is: 1000V 60mA
Old 13th January 2018, 07:44 AM   #6
jazbo8 is offline jazbo8
jazbo8's Avatar
211SE with 14K Trs
They are beautiful, and thanks for sharing the design!
Old 13th January 2018, 01:46 PM   #7
waltube is offline waltube  Italy
waltube's Avatar
The FB loop exist
Not from out but from driver stage
Walter
Old 13th January 2018, 04:46 PM   #8
rdf is offline rdf  Canada
rdf's Avatar
Originally Posted by L CAO View Post
Test Results:
That's truly impressive performance. What are the output transformers?
Ears aren't microphones.
Old 13th January 2018, 05:20 PM   #9
artosalo is offline artosalo  Finland
artosalo's Avatar
Performance (THD vs. output power) at 1 kHz is not fully informative.
But how is it if measured below 30 Hz.
Old 13th January 2018, 08:32 PM   #10
Lingwendil is offline Lingwendil  United States
Lingwendil's Avatar
Clever feedback, clean assembly, and nice numbers. Great build. Glad to see a little feedback in a DHT design, the zero-NFB craze is too overdone and it's nice to see something that isn't just thrown together!
Great job.
211SE with 14K TrsHide this!Advertise here!
