Fixed bias PSU questions
Old 11th January 2018, 11:51 AM   #1
Tyimo is offline Tyimo  Hungary
Default Fixed bias PSU questions
Hi
In the case of using fixed bias what are the requirements of the power supply?
- what power transformer? How many VA? e.g. for 6C33CB tubes
- What kind of quality rectifier, caps, resistors etc?
greets:
Tyimo
"Replacing any coupling capacitors with a well designed and correctly matched driver or interstage transformer yields an almost shocking improvement in sound..." Peter Qvortrup
Old 11th January 2018, 01:05 PM   #2
kodabmx is offline kodabmx  Canada
In my KT88 amp I use a 12VA 48V transformer (Triad F48-250-C2), HER208 in a bridge, CRC filter (220u/1k/220u). Works fine for me. Generally 250ma is more than enough current.
Old 11th January 2018, 01:12 PM   #3
Eli Duttman is offline Eli Duttman  United States
A C- (bias) supply is a low current situation. Only a few mA. flow, when the NET voltage on the grids approaches zero. Combine those few mA. with the losses in the trim pots. and you have the requirement. From a practical standpoint, rail voltage (which is design dependent) is the critical number.
Many power trafos have a bias tap on the rectifier winding that is 1/2 wave rectified. A spare filament winding can be voltage multiplied to generate the volts needed. As this is a negative rail, reverse the diode polarity shown in the uploaded graphic. Use Schottky diodes to minimize forward drop losses, along with being "noise free".
Eli D.
Old 12th January 2018, 01:20 PM   #4
Thank you!
Old 12th January 2018, 02:49 PM   #5
goldenbeer is offline goldenbeer  Germany
You should not operate 6C33C toobs in in pure fixed bias.
Old 12th January 2018, 03:36 PM   #6
Why not?
Old 12th January 2018, 05:03 PM   #7
Look at the 6C33C datasheet. Notice, the 200 Kohm grid to ground resistance limit, which may be for self biased arrangements. The type is extremely vulnerable to runaway. "Fixed" bias exacerbates the runaway character of tubes. If you employ combination bias, with a relatively small portion of the TOTAL bias voltage coming from a RC network, the operating point is stabilized.
Arrange your driver circuitry so that a 47 Kohm grid to gound resistor is not problematic and "stand" the cathode on a 100 Ω/470 μF. network. The RC network stabilizes the operating point and provides a convenient "idle" current test point.
Eli D.
Old 13th January 2018, 05:32 AM   #8
PRR is offline PRR  United States
PRR's Avatar
Originally Posted by Eli Duttman View Post
...200 Kohm grid to ground resistance limit...
It is a Pass Tube. In the intended application, the load it is powering is in-effect a giant cathode resistor. The pass tube can't flow more than the load will take. And typically a pass tube driver has large down-swing to throttle a runaway.
Considering that lesser tubes spec 50K in fix-bias, I agree this monster should not be near 200K except with mostly cathode bias.
Old 13th January 2018, 11:31 AM   #9
Thank you!
Fixed bias PSU questionsHide this!Advertise here!
Fixed Bias (no bias control) and Upgrading Output Transistors timber wolf Solid State 12 16th June 2015 12:01 AM
DC Automatic Bias Control - Auto fixed bias Ceglar Tubes / Valves 21 11th October 2014 09:21 AM
EL84 fixed fixed bias razorrick1293 Tubes / Valves 3 20th November 2011 03:33 PM
Battery grid bias to fixed bias in Toccato? w00t Tubes / Valves 3 2nd December 2007 12:34 AM
Fixed bias PP questions SHiFTY Tubes / Valves 1 10th July 2004 12:42 PM
