A WE-91B project
A WE-91B project
Old 16th January 2018, 01:44 AM   #21
jerrylong is offline jerrylong  China
Power PCB
Old 24th January 2018, 02:38 AM   #22
The PCB is here
Old 29th January 2018, 08:45 AM   #23
Here is the chasiss
Old 30th January 2018, 11:48 AM   #24
Khaleesi is offline Khaleesi  Australia
Khaleesi's Avatar
I want to keep the first 310A to keep the original circuit as possible, and add a attenuator between the pre and 91B
You are going to add an attenuator to reduce the signal because you are going to use a step up transformer in the next stage which would otherwise cause overload??
Please correct me if I am wrong.
Old 1st February 2018, 03:05 AM   #25
No I just want to add an attenuator between the pre and WE-91B, I wll not use a step-up trans in the Input of the WE-91B
Old 1st February 2018, 11:48 AM   #27
JOHNNYCR100 is offline JOHNNYCR100  Abu Dhabi
Default Nice amp sir
Hi there Jerry, thanks for shareing, do you intend a WE type preamp to keep the synergy?, newbee question -but a modern/retro We system seems a great idear - how much like the origional would this sound like (another newbee question)- Would you need horns (Sato horns?) to finish the effect, I say this as i once heard a WE amp with horns and i never forgot the sound (road to Damascus experence)
Cheers Johnny
Old 2nd February 2018, 12:34 AM   #28
Hi Jonnny, thanks for noticing this project. I will use my AudioNote M10 (clone one) with this WE-91B to see the effect first. I have a TAD2402 horns(sensitivity is 97dB), I think it will be good for the WE-91B.
Old 2nd February 2018, 04:00 AM   #29
Default Nice horns!
Hi Jerry,
Love those horns, I have been reading about the history of WE amplification ( inspired by your build somewhat) but the origin WE amp used for cinema amplification apparently (so I read) only went to 15 Khz, amp makers traffomatic claim the have a modern WE amps with none of the high frequency restrictions but to in house output transformers, is this embedded in your WE inspired approach?, assuming it is could you give any more info on the output transformers you used please.
Maney thanks and well done.
Regards Johnny
Old 2nd February 2018, 10:30 AM   #30
I will make all the transfomers in this project include OPT, I am still designing it now
A WE-91B projectHide this!Advertise here!
The BiAmp (aka My LM4766 + 6p15p project, and LM1875 project.) valtra103 Chip Amps 21 4th December 2015 08:32 PM
Newby project idea for HND main project help and advice needed please WIGANWEZ Chip Amps 1 17th September 2011 04:59 PM
Newby project idea for HND main project help and advice needed please WIGANWEZ Chip Amps 0 17th September 2011 01:39 PM
CDPRO2 Group Project (open source project) BrianGT Digital Source 147 8th August 2008 11:37 AM
