A WE-91B project
A WE-91B project
Old 10th January 2018, 05:07 PM   #11
TheGimp is offline TheGimp  United States
TheGimp's Avatar
I believe it is actually NFB due to the way it is feed back to the screen instead of the grid, and taken from the plate of the output tube.
Note 7 seems to confirm this in stating that shorting the 70K feedback resistor results in 10dB less gain. Shorting the 70K feedback resistor allows more feedback.
If there are no dogs in Heaven, I don't want to go there.
Old 10th January 2018, 05:20 PM   #12
Koonw is offline Koonw
I have edited for you, but you can do even better :-). This is really a very hot amp dispite the NFB inplace.
Old 11th January 2018, 01:22 AM   #13
jerrylong is offline jerrylong  China
Thank you very much. Your correction is really helpful. Giving me more confidence to finish this project
Old 11th January 2018, 09:40 AM   #14
jazbo8 is offline jazbo8
jazbo8's Avatar
A WE-91B project
Oops, you are right.
Old 12th January 2018, 07:28 AM   #15
the Power Trans design:
a=38mm(EI-114),b=55mm
Prim:
220V~472T/0.54mm
230V~494T/0.54mm
Sec:
420V(1010T/0.285mm)~400V(962T/0.285mm)~0~400V~420V/160mA
5V/2.5A(12T/1.129)
2.5V(6T/1.129mm)~0~2.5V/2.5A
5V(12T/1.129)~0~5V/2.5A
Old 12th January 2018, 07:42 AM   #16
The choke design:
EI-96
a=32mm, b=35mm
3500T/0.31mm
L=20H
Old 12th January 2018, 07:54 AM   #17
The OPT design:
Prim:2400T/0.33mm
Sec:0~4ohm(88T/0.55mm*3)~8ohm(123T/0.55*3)
Old 12th January 2018, 07:56 AM   #18
davorin is offline davorin  Croatia
Air Gap?
L=16H for Idc-max=?
Old 13th January 2018, 05:19 AM   #19
It is really hard to find these 2 16uf capacitor, is it OK to use 20uf/450V to replace?
Old 16th January 2018, 01:22 AM   #20
chassis design
A WE-91B projectHide this!Advertise here!
The BiAmp (aka My LM4766 + 6p15p project, and LM1875 project.) valtra103 Chip Amps 21 4th December 2015 08:32 PM
Newby project idea for HND main project help and advice needed please WIGANWEZ Chip Amps 1 17th September 2011 04:59 PM
Newby project idea for HND main project help and advice needed please WIGANWEZ Chip Amps 0 17th September 2011 01:39 PM
CDPRO2 Group Project (open source project) BrianGT Digital Source 147 8th August 2008 11:37 AM
