A WE-91B project
A WE-91B project
Old 15th April 2018, 12:48 PM   #111
jerrylong is offline jerrylong  China
Thanks for noticing this project, could you give some advice to this project?
Old 15th April 2018, 03:45 PM   #112
hooman is offline hooman  Iran
hooman's Avatar
1-hi sensitivity speaker =hear very small signal from amp !!!it is very bad chans in tube amp .
2-dht out put =noise in output . dc filament with good filtering and 100 ohm balance pot .some times i use battery for filament to understand source of hum .if change ...should try on filtering of dc for filament .
3-disconnect the signal of tube driver to 300b and see the oscop .if have hum try to fix it .
4- reduce hum in out put dht tube is not difficult .but most of problem happen in gain stage and first tube .this kind of hum need spend time to detect source of hum .
iranaudiotube.blogfa.com
1979.....i lost everything
Old 15th April 2018, 04:33 PM   #113
hooman's Avatar
to day i working on guitar amp hum .45 mv hum is problem on guitar speaker .
Old 16th April 2018, 04:01 AM   #114
Thank you hooman, very good advice. This experience will help me a lot
Old 16th April 2018, 04:02 AM   #115
Attachment 675348
Use battery to the heater, quite a good testing method, how to connected it to 300B filament?
Old 16th April 2018, 02:32 PM   #116
hooman's Avatar
hi
Old 16th April 2018, 05:33 PM   #117
Thanks a lot, you are quite a artist of drawing◝A WE-91B project
Old 16th April 2018, 07:07 PM   #118
hooman's Avatar
2 YEARS before i send circuit and parts to my customer for 300 b amp project .pleas look at the power supply and amp .first i design circuit whit c3m...vt25...300b...
2 dht !!
before to assemble and make box by customer ...i test all of circuit and check sound with hi sensitivity speaker .
hum=0
musical sound
no pcb .
Old 17th April 2018, 12:26 AM   #119
Begin to rebuild the second one of this mono.
Two changes:
1, used shield twisted cable for heater
2, change connection point of two 310A, from 1st stage to 2nd stage
Old 18th April 2018, 05:13 PM   #120
Reduced the noise to 6mV(input VR to min and max)
When input VR at the middle nosie rised to 19mV, connected the shell of VR to chassis, noise reduced to 8mV
A WE-91B projectHide this!Advertise here!
The BiAmp (aka My LM4766 + 6p15p project, and LM1875 project.) valtra103 Chip Amps 21 4th December 2015 08:32 PM
Newby project idea for HND main project help and advice needed please WIGANWEZ Chip Amps 1 17th September 2011 04:59 PM
Newby project idea for HND main project help and advice needed please WIGANWEZ Chip Amps 0 17th September 2011 01:39 PM
CDPRO2 Group Project (open source project) BrianGT Digital Source 147 8th August 2008 11:37 AM
