Killer OTLs
Killer OTLs
Old 30th December 2017, 04:02 AM   #11
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
Killer OTLs
Default killer OTL's
Hi Kasanay, do you have any documentations that we can look at? links?
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 30th December 2017, 03:57 PM   #12
dady is offline dady  Balearic Islands
dady's Avatar
Send a message via MSN to dady Killer OTLs
Originally Posted by kasanay View Post
There are (30) 12B4As which have rP of 1030.
1030 / 30 = 34.4. About perfect for 32 ohm speakers.
With negative feedback you bring much more down than this....
In totem pole you down by four.
Esteban Bikić
Old 31st December 2017, 03:44 PM   #13
kasanay is offline kasanay  United States
So, I really don’t understand this topography. I think we should move this out of the photos gallery forum and maybe I’ll get some education!
Old 1st January 2018, 10:23 PM   #14
kevinkr's Avatar
Killer OTLs
Presumably it is based on the Futterman design. I imagine all of those electrolytics now need to be replaced, and there are a lot of them.
It probably sounded pretty good, no one would have gone to this amount of trouble at that time for any other reason.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 1st January 2018, 11:04 PM   #15
TonyTecson's Avatar
Killer OTLs
OTL's indeed sounds good, they are also fast, whatever that means...
Old 2nd January 2018, 12:46 AM   #16
smoking-amp is offline smoking-amp  United States
smoking-amp's Avatar
Looks like it says:
MP Engineering Co. Fairfield ? Conn.
I used to live near there.
They don't seem to have read the RCA manual on safe spacing of tubes!
Maybe there is a big fan that blows on each bank of tubes?
Geez, 12B4 are only good for 30 mA each. Someone must have requested this strange design. I can't see marketing that.
Old 2nd January 2018, 01:36 AM   #17
PRR is offline PRR  United States
PRR's Avatar
Originally Posted by smoking-amp View Post
...Geez, 12B4 are only good for 30 mA each.....
But 105mA Peak. The most peak in the smallest bottle of any TV-shop tube.
The rp/30 number is a miss. We have to swing the peaks with only 15 tubes. Assuming 105mA it works to 75 Watts in 60 Ohms. Not shabby, if the load can be 60 Ohms.
The rating is for TV V-sweep duty, 105mA peak 60 times a second 6 hours a day all year. Speech/music does not peak very often. If 12B4 are inexpensive, we can hit them harder. Plotting 150mA peak gets near 62W in 24 Ohms. If the speakers turn out to be 30-60r where it matters, the power will be in this 60W-70W range.
The load goes over the Pdiss line. This can be OK. For full-Sine power output, we should compute or measure the plate dissipation. For speech/music, this much over-Pdiss will be fine.
Other plots are possible. 12B4 has positive-grid plots, and we could work-out a class 2 design. But Ig goes up so fast the drive requirements get huge before much is gained.
Old 2nd January 2018, 01:58 AM   #18
You are right of course, it CAN be done.
But sometimes BIGGER is Better. 6LX6 or 6LW6, 1400 mA peak in the footprint of just 4 of those tubes. Only 2 BIG tubes needed for the whole amplifier.
But then, it probably HAD to be triode. So 30 tubes. I'll bet they ran for 500 hours, cooked some tubes in the center, maybe blew the woofer, cost too much to fix, and was abandoned shortly thereafter. The MP Engineering company name fading into obscurity.
Old 2nd January 2018, 03:11 AM   #19
Although triode outputs provide a certain mystique for sound quality, usually that means loading them at 5X their internal rp to get that. So to justify triode output tubes, this amplifier really needs 5 times as many tubes. Otherwise, you just have a typical high N Fdbk amplifier.
150 12B4 tubes per amplifier! (for a 30 Ohm speaker, 4 times that for an 8 Ohm speaker, 600 tubes per amplifier)
Reliability would be approaching the ENIAC computer, 30 minutes maybe. (OK, a few days) Cost would be out of sight. Power consumption and heat unreal. Repair-ability would mean on-site personnel with test equipment. I don't think this design was really well thought out over-all.
And does it have speaker protection? A 4 or 5 to 1 OT would provide that with minimal affect on sound quality and would bring the tube quantities back down.
A triode emulation scheme could even provide "triode sound" with just 2 big output tubes. 150 Watts output on one chassis.
Well, hind-sight IS wonderful. I don't know what options they had 60 years ago.
Old 2nd January 2018, 03:23 AM   #20
TonyTecson's Avatar
Killer OTLs
why are people allergic to pentodes? most of the time they had to emphasise triode....
Killer OTLsHide this!Advertise here!
The Tube Killer Killer? Sch3mat1c Tubes / Valves 7 16th November 2010 03:15 PM
WTB: Transcendent OTLs Studley Swap Meet 0 30th October 2008 08:53 PM
low power OTLs vizion Tubes / Valves 4 20th October 2007 05:01 PM
Variac to power-up Beveridge OTLs? david yost Tubes / Valves 1 16th September 2007 06:11 PM
Noise Killer Soulwax Multi-Way 2 9th November 2005 02:58 AM
