Rectifier leak PSUD
Rectifier leak PSUD
Old 31st December 2017, 02:49 PM   #1
mr ed is offline mr ed  United States
Default Rectifier leak PSUD
Any one know what the setting in options menu for PSUD2 for rectifier leak pertain to?
How do I determine what to use?
Ed
currently watching electrons party under glass
Old 31st December 2017, 09:12 PM   #2
trobbins is offline trobbins  Australia
trobbins's Avatar
From the Help section:
Menu
Use the mouse or keyboard to select items from the menu:
Options menu
Options | Rectifier leak Allows various reverse leakage resistances to be dialled in. This is helpful for getting rid of kickback on choke input power supplies.
So it adds a resistance across the diode (not a standard parameter in the diode model). In numerical simulations, there is often a need for some resistive path between nodes. If you want to use a non-default value, then change it and compare waveform results and important calculation values of interest to you so that you can appreciate the sensitivity of that optional value.
Old 31st December 2017, 11:14 PM   #3
Thanks for reply,
I had planned a snubber betwwen transformer and rectifier tube but did not now how to sim, this makes sence
Cheers
Old 1st January 2018, 01:50 AM   #4
trobbins's Avatar
PSUD2 would not be appropriate for any form of snubber assessment. The calculation engine is simplified, compared to say LTSpice, and doesn't allow an RC or even a C between transformer and diodes, and doesn't model the leakage inductances within the transformer (ie. the reason for snubbering). Any high frequency waveform responses plotted in PSUD2 need to be viewed with caution.
I can recommend you work through the Quasimodo threads if your aim is to pursue simulating snubber performance.
Rectifier leak PSUDHide this!Advertise here!
5u4 rectifier -- PSUD II waltroman Tubelab 4 5th February 2015 07:13 PM
Hybrid rectifier possible in PSUD? CarlyBoy Tubes / Valves 1 7th January 2013 12:34 PM
valve rectifier in PSUD jrenkin Tubes / Valves 21 24th May 2010 10:21 PM
Leak Stereo 20 - solid state rectifier? bremen nacht Tubes / Valves 17 7th July 2005 05:41 AM
Anybody heard about Tarzian Silicon Rectifier for Tube Rectifier Replacement? zxx123 Tubes / Valves 4 21st February 2005 04:02 AM
