2A3 cathode resistor
Old 2nd January 2018, 08:08 AM   #21
soulmerchant is offline soulmerchant  Switzerland
soulmerchant's Avatar
Ok, so you want to keep it all tube. But do you want good sound? The source follower I suggested is really just a cheap and easy way to prove to you that your 12ax7 isn't up to the task of driving your 2a3's.
Once you realize that, you can consider other options to keep it all tube. But maybe none of this matters? Since you're still on a breadboard I would certainly suggest trying a triode strapped pentode instead. In your neck of the woods I might think about maybe trying triode strapped 7788.
It's harder to make real audio than special effects audio.
Alejandro Gonzalez Inarritu
2A3 cathode resistorHide this!Advertise here!
CCS instead of a resistor in the cathode of a cathode follower? Nailbunny7 Tubes / Valves 38 19th April 2016 07:58 AM
TSE Cathode Resistor craigtone Tubelab 1 23rd January 2016 11:37 PM
Cathode resistor crazy bill Tubes / Valves 5 11th October 2014 01:17 PM
Cathode resistor calc? M Gregg Tubes / Valves 1 13th January 2011 08:04 PM
TVA-1 cathode resistor value audiohead Tubes / Valves 3 9th December 2007 07:15 PM
