I'm building a PSE 1625 amplifier (12HG7 driver, regulated screens, plate-to-pate feedback) and seem to be running into some RF issues when the two output tubes are plugged in. The amplifier does work better with one output tube installed, but hum and audible distortion greatly increases with two in parallel.
Thinking of adding plate stoppers in an attempt to handle some of this nastiness. Also more R-C separation for the screen supplies.
Question - what's the best way to mount a carbon comp resistor to a plate cap? Pictures would be nice!
Like this:
Preferably with a resistor that hasn't cracked from overheat though..
And I would not do such bad soldering .
Tinning is for wimps.
It is probably an RF PA. Hence the low coil inductance. Some of the RF will go through the resistor, and it will probably suffer from temperature cycling during a typical QSO. However, even a cracked CC resistor will add some loss to the coil.artosalo said:Fortunately it is not mine. The picture is from QRZ forum.
- Tubes / Valves
- Stoppers for plate cap tubes
