100Hz Hum in Valve Amp
Old 7th December 2017, 07:28 PM   #11
azazello is offline azazello  Bulgaria
azazello's Avatar
Originally Posted by Merlinb View Post
That is possibly the most expensive and least logical first step.
100 Hz comes from worst filtering of +U and adding chock for 30 Eu will decide most of hmmm problems, or try starting iron chock for luminiscent tubes with R 30 - 40 ohm. /Input tracks and grounding cause 50 Hz hmmm/.
Projects: OTL-OCL 6AS7 Gen. Electric, SEs 2A3 RCA, 300B JJ, 6S4S, 4P1L, EL11 Telefunken, 6AS7 RCA, 6S33S, 6S41S, 6S19P, E84L Siemens, E236L Telefunken, headphone ampl. OTL Loftin White 6AS7 RCA,... PPs 6005 Gen. Electric, EL34 Mullard, 6L6....
Old 7th December 2017, 07:37 PM   #12
Bassy is offline Bassy  United Kingdom
Thanks for all the replies and apologies for the lack of schematic, it's on my old pc but I'll post it tomorrow some time. The inductive or capacitive coupling sounds possible, some but not all of the signal wires are shielded and there could be a gap somewhere. I have checked and rechecked grounding but I'll check again in case I've missed something.
100Hz Hum in Valve AmpHide this!Advertise here!
100HZ PLLXO TheTubeAmper Analog Line Level 13 26th October 2016 10:27 AM
100Hz-200Hz peak Andrewleclerc93 Multi-Way 8 15th January 2016 08:22 AM
Output transformer for 100Hz and up ErikdeBest Tubes / Valves 22 29th September 2015 09:08 PM
DHT 100hz hum marcelop Tubes / Valves 6 4th March 2014 06:26 PM
question on rolloff below 100Hz wintermute Chip Amps 4 16th December 2003 04:23 AM
