ebay 6J1 valve pre-amp - circuit diagram/gain
Old 19th December 2017, 11:06 AM   #21
02GF74 is offline 02GF74  United Kingdom
Originally Posted by Bandersnatch View Post
As long as their PIV rating and current capacity is adequate.
cheers,
Douglas
With 12v ac supply I understand that the capacitors and diodes won't see more than 12v rms.
So to reduce the vf across the diodes, a 1n5817 should be fine.
Spec below.
Code:
              1N5817  1N58185  1N5819
Vr peak   	20       30   	   40
Vrms      	14   	  21   	   28
Vf @ 0.1A      0.2       0.3      0.6
Vf @ 0.2A      0.25      0.35     0.75
Old 2nd January 2018, 06:23 PM   #22
Been busy modifying the board to use 7812 regulator for heaters (with diode to raise to 12.6v) and cutting tracks to make it cathode follower.
What effect will leaving r13/r18 (470k) tied to - 39 v instead of to 0v? Would save a fair bit of work.
Old 2nd January 2018, 08:10 PM   #23
Ketje is offline Ketje  Belgium
Ketje's Avatar
Practicaly no current in the cathode follower.
Mona
Old 2nd January 2018, 10:14 PM   #24
^^^^ I take it that it will be OK.
I thought maybe it will pull down the input too far.
Old 3rd January 2018, 10:56 AM   #25
DF96 is offline DF96  England
Take it that it will not be OK.
There are essentially two ways to bias a cathode follower: apply the correct DC voltage to the grid, or use a small value cathode resistor. If you connect the grid resistor to -39V instead of 0V then you are applying the wrong DC voltage to the grid so the valve will conduct almost no current so create significant distortion.
Old 3rd January 2018, 11:13 AM   #26
Many thanks for the reply, arrived in just in time as I'm about to continue with the modifications. Luckily I can avoid cutting the negative pcb tracks as there are two vacant pcb holes to 0v where the potentiometer used too.
Old 3rd January 2018, 02:51 PM   #27
Completed mods and except for one mistake have it working, top and underside of board below.
The regulated supply to the heaters has eliminated buzz in L channel (was present with no input and pre-amp volume turned to 11) but when testing I could see on the 'scope there is a fair bit of crosstalk, which can be heard with signal applied to only 1 channel, (pre-amlp volume at 11).
I did same listening test on the original circuit - and there was similar cross talk on R channel.
So I am wondering as to the reason for this. My own opinion of the layout is not great - I would have kept inputs on the opposite side to the outputs.
1. there is pick up as the two input signal tracks run parallel to each other (see underside, lowest 2 horizontal tracks
2. the signal leaks across either through the 0 V rail (R13/18) or via the -ve rail (R14/19)
3. other?
update: even with valves removed and circuit not powered, seeing crosstalk. Resistance between both inputs as shown by dvm is ∞.
suggestions as to where to look?
Old 3rd January 2018, 03:23 PM   #28
update 1: even with valves removed and circuit not powered, seeing crosstalk. Resistance between both inputs as shown by dvm is ∞.
update 2. as above; at about 100 Hz, I'm seeing the amplitude on the unused input start to rise and reach maximum at about 60 kHz - that to me seems to imply pick-up on the parallel tracks?
I'm wondering whether it is worth cutting the tracks for the inputs and replacing with screened cable?
Old 3rd January 2018, 06:32 PM   #29
A quick rework to move input signals apart has massively reduced crosstalk. Also heatsink for the regulator.
Old 4th January 2018, 11:27 AM   #30
Crosstalk which rises with frequency is due to either capacitance between high impedance points, or inductance in a common circuit loop (typically a ground connection).
ebay 6J1 valve pre-amp - circuit diagram/gainHide this!Advertise here!
Just a simple current gain stage with bias control to club with high gain valve pre rhythmsandy Solid State 4 5th May 2017 10:15 AM
diagram for OTP 6.6K valve KT88 Danchu Tubes / Valves 17 23rd September 2008 10:56 AM
Circuit Diagram epacor Parts 1 3rd February 2007 07:42 AM
Help! circuit diagram vodaTube Tubes / Valves 0 8th July 2005 07:49 AM
