However, a good circuit will maintain its performance over a wide range of valve parameters so you should not hear any change.
What do you mean by good circuit? How do you know the circuit is good? Do you look at the schematics and determine if the design is good? So I assume you guys use the tube till it breaks?
Various things, including the performance being insensitive to valve parameters.flargosa said:What do you mean by good circuit?
Knowledge, experience plus a calculator.How do you know the circuit is good? Do you look at the schematics and determine if the design is good?
There are several common ageing/failure mechanisms in valves:
1. open circuit heater
2. gas
3. loss of emission
- Tubes / Valves
- Do tubes lose resolution as it ages?
