Need help to make Quad II OPT SPICE Model
Old 24th November 2017, 04:53 PM   #21
jazbo8 is offline jazbo8
jazbo8's Avatar
Yup, that's it.
Old 6th December 2017, 03:00 AM   #22
jerrylong is offline jerrylong  China
Now I am beginning to make the OPT, this is the winding arrangement, any suggestion?
Old 6th December 2017, 06:45 AM   #23
Kay Pirinha is offline Kay Pirinha  Germany
Kay Pirinha's Avatar
Doesw anyone understand the info given about the transformer's EI core? What is T, S, L, and H? And what does that ominous resistor R between L1 and L3 mean that has already been showing up in the diagram in posting #7?
Best regards!
"Bless you, Sister. May all your sons be bishops." (Brendan Behan)
Old 6th December 2017, 07:48 AM   #24
the R between L1 and L3 is about 0.36ohm
Old 6th December 2017, 07:51 AM   #25
jazbo8's Avatar
T, S, L, and H are the notations for the internal terminals of the OPT, which are not accessible, unless you take off the transformer housing.
Old 6th December 2017, 07:54 AM   #26
From the core info (2nd pic in #22): T = 25 mm, S = 25 mm, L = 42 mm, H = 22 mm. I can't believe that this relates to any electrical connection.
Best regards!
Old 6th December 2017, 08:00 AM   #27
jazbo8's Avatar
Turner's notations of EI cores:
Old 19th December 2017, 02:57 AM   #28
This is the coil arrangement
Old 19th December 2017, 02:58 AM   #29
This is N1
Old 19th December 2017, 04:17 AM   #30
The second L1
Need help to make Quad II OPT SPICE ModelHide this!Advertise here!
Spice model for GU50 (LT-Spice) voltagezone Tubes / Valves 44 19th November 2013 08:05 AM
opa627 Spice Model vs Ideal Opamp Model HiFiNutNut Chip Amps 7 16th September 2013 10:40 PM
Quad 405 Spice Model 405man Solid State 4 26th April 2007 06:05 AM
SPICE model Prune Software Tools 6 16th October 2004 03:22 PM
Spice model doigtee Tubes / Valves 6 12th July 2003 11:42 AM
